What size FEL plow - Kubota MX5100?
   / What size FEL plow - Kubota MX5100? #11
BTW, what brand of blade is that you've got on your 5740?
Ironically, the angle plow is a JD SB9. It's a decent blade, but there are much better out there. I got it cheap.
   / What size FEL plow - Kubota MX5100? #12
I'd suggest compromising and go with a 7.5 foot plow. Our tractor/loaders are similar in size in weight, this what my 7.5 footer looks like from the front. Granted it sticks out a little further then a loader designed plow because its made for a truck. It pushed 2 feet of snow pretty well (Ag tires) but I can see why others would go with a seven footer. Also, do you have a garage? This plow just barely fits through my door without angling it, your garage door size may be a consideration.
Good thought, we have one door that is taller/wider but I always forget what it measures.
   / What size FEL plow - Kubota MX5100? #14
I think a plow that is suspended by a chain would be the best way to go after using mine a little. You can keep the weight of the loader on the front axle.
