Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    New Member
    Join Date
    Feb 2013
    Posts
    9
    Steep Falls Maine
    John Deere 650
    Default John Deere 650 utility tractor front mount snowblower
    I just bought a 1987 John Deere 650 geared utility tractor. I'm looking for a front mount snow blower. I talked with my local John Deere dealer and he said there was only one model that fit it and it didn't perform well. The rear three point hitch snow blower doesn't perform well either because high range is too fast and the low range is too slow. Is there any one out there who has one that works and if so what model# and do they still make them.
    Thank you,
    Peter from Maine
  2. #2
    Join Date
    Nov 2007
    Posts
    790
    PA
    Kubota L3130 HST 4x4
    Default Re: John Deere 650 utility tractor front mount snowblower
    I used a rear mouned snowblower for 10+ years on a 750 and it worked well. I believe the front mount snow blower requires an add-on electric clutch belt driven off the front pully. I don't believe it is available any longer from JD although it sometimes is available on ebay. The rear blower I had was 60" wide.
    John Deere 650 utility tractor front mount snowblower-dsc_0408-jpg John Deere 650 utility tractor front mount snowblower-dsc_0420-jpg
    Kubota L3130 HST 4x4, FEL LA723 w/QA and BH90 Backhoe
    Kubota L4740-3 Cab, HST, FEL w/Heavy duty bucket w/cutting edge
    Snow Blower: L2185 72" front mount w/hyd rotation and electric chute, 7' back blade, carry all, 48" Pallet Forks w/QA, Sun Shade, Turf tires & Rubber Chains for the winter, Extra forward and rear lighting. BearCat 73454 Wood Chipper. LandPride RCR2672 Rotary Cutter. Ballast Box Approximately 390 hours on L3130
  3. #3
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Murph
  4. #4
    New Member
    Join Date
    Jan 2013
    Posts
    24
    North Milton, Prince Edward Island, Canada
    John Deere 650, 2008 Ram 1500
    What size snowblower isn't performing well? I have a 48inch farm king for mine
  5. #5
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    Welcome to TBN.
  6. #6
    New Member
    Join Date
    Feb 2013
    Posts
    9
    Steep Falls Maine
    John Deere 650
    Thank you for the info it was helpful.
    I have a electric front pto style clutch for my mower.
  7. #7
    New Member
    Join Date
    Feb 2013
    Posts
    9
    Steep Falls Maine
    John Deere 650
    Hi,
    Im looking to see if anyone has or has used a front mount snowblower on a 650JD tractor.I checked with my local dealer he said they didnt work well in 1987 that is the year of my tractor.
    Peter in Maine
  8. #8
    Elite Member Briana03's Avatar
    Join Date
    Jul 2010
    Posts
    3,292
    San Diego, California
    None
    Welcome to TBN
    I moved your thread to the Snow Removal forum.
    Briana
    TBN Support
  9. #9
    Join Date
    Jan 2006
    Posts
    963
    West Central Idaho
    Kubota L5740HSTC3; B3000HSDCC
    You may find it difficult to operate a pto snowblower with a geared tractor, unless the tractor has a "supercreep" gearing capability. Full blower speed must be maintained to operate the blower properly, and that translates into higher engine rpms for the pto. Without a supercreep, you will resort to constantly slipping the clutch to match tractor speed (slow) to accommodate the snow load into the blower.
    Even a hydraulic powerpack (for a hydro blower) will require high PTO input (higher engine rpm) which would still leave you with a ground speed problem.
  10. #10
    New Member
    Join Date
    Feb 2013
    Posts
    9
    Steep Falls Maine
    John Deere 650
    thank you this was helpful
Similar Threads
  1. John Deere 650 tractor
    By skyhawk53147 in forum Parts/Repairs
    Last Post: 07-02-2014, 09:18 PM
  2. Buying Advice Tractor for Front Snowblower: John Deere X748 or Kubota BX2360 for $3K Less?
    By MichSnowBlower in forum Buying/Pricing/Comparisons
    Last Post: 09-27-2011, 03:44 PM
  3. Snow Attachments John Deere Front Mount Snow Blower
    By bul1seye in forum Snow Removal
    Last Post: 03-10-2011, 11:10 AM
  4. Front-End Loader John Deere 650 compact tractor
    By dodge919 in forum Attachments
    Last Post: 03-06-2010, 07:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
