Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
  1. #11
    Veteran Member ericher69's Avatar
    Join Date
    Aug 2008
    Posts
    1,670
    Ontario Canada
    2008 Kubota b2920
    Default
    Quote Originally Posted by rasorbackq View Post
    Seen a graet deal on a 5 ' but thoght it was too small.
    Thanks.
    Get the great deal on 60" and add "wings" to each side!
    I added them to my 51" to a total width of 63" and it works great (dare I say even better than stock?)
    ericher69
    IAFF Local 849
  2. #12
    Gold Member
    Join Date
    Aug 2011
    Posts
    430
    Springfield Nova Scotia Canada
    Branson 4720
    Default Re: Snow blower width
    Add wings meaning cut off the ends and lengthen?
  3. #13
    Join Date
    Mar 2007
    Posts
    1,020
    British Columbia, Canada
    1959 MF-65 sold, 2007 Jinma 554 diesel.
    No, but fit as shown in the picture of my old blower.
    Attached Thumbnails Attached Thumbnails Snow blower width-snow-blower-wings-4-jpg
    2007 Jinma 554 tractor, FEL, 8ft Rear Blade, 73" Snowblower, 2002 3500 Dodge Ram 4x4, 1986 F250 4x4 SC 6.9 turboed diesel.
  4. #14
    Super Member WilliamBos's Avatar
    Join Date
    May 2004
    Posts
    5,038
    Innisfil, Ontario, Canada
    MF 1635 12x12 Powershuttle
    Quote Originally Posted by uglyboywith11fingers View Post
    that may be a 'qualified' myth, Will... years ago I had a Bolens 1050 with a 36" single stage blower on the front. Even in 1st gear low range, I was riding the clutch a lot in heavy snow... HST would have been nice.
    You could argue a Bolens 1050 is not a real tractor, I suppose... but it did a lot of work for me the 28 years I had it.
    Pete
    I love tjose older garden tractors. I wish they were stillbuilt like that. Dad had an MF 12, then a Ford LGT165.
    Thanks,
    Will
    2017 Ram SXT 1500 Crew Cab 4x4 5.7 Hemi 6 speed auto.
  5. #15
    Join Date
    May 2004
    Posts
    5,038
    Quote Originally Posted by doxford jim View Post
    We did the same, went from 50-64". Works better now.
    Thanks,
    Will
  6. #16
    Join Date
    Aug 2008
    Posts
    1,670
    Ontario Canada
    2008 Kubota b2920
    Default
    Here is a video of how it now funnels the snow in instead of spilling out
    http://youtu.be/pxp6TQ64QNw
    ericher69
    IAFF Local 849
  7. #17
    Elite Member Tig's Avatar
    Join Date
    Oct 2006
    Posts
    2,557
    The County, Ontario, Canada
    Kubota, B7100HST-D
    Quote Originally Posted by MF 1532 View Post
    What would be a guess for h.p. needed per foot ?
    I've heard 5hp/ft, but I needed 50" to cover my tracks and I get by on 13 PTO HP and HST.
    Steve
    The best things in life are not things.
  8. #18
    Join Date
    Mar 2011
    Posts
    608
    Florida Ma.
    Ford 1720 SSS 4x4 Turbo Charged
    It is no Myth!
    A Hydro transmission has infinite speeds so you can feed the snow blower into the snow as fast or slow as the engine HP allows. Gear transmissions do not allow this so when you encounter extreme conditions (heavy deep snow) excessive use of the clutch is needed to avoid stalling.
    I live in New England and my 28hp (24 PTO) 1720 Ford SSS with 12 forward & reverse gears would frequently run out of power even in 1st gear using a 64” snow blower. Constant use of the clutch was necessary to prevent stalling the engine. I would consider this abuse of the clutch.
    Just to clarify my tractor is not running poorly. I eventually I installed a turbo and the increased HP which solved my problems.
    A smaller Hydrostatic Ford tractor using the same snow blower handled it with no problems. Ground speed is the key to proper operation.
    Correct me if I’m wrong but a power shuttle still uses forward & reverse clutches and are still wear prone.
    Based on my personal experience with up to 12~18 inches per storm and snow banks that are 24~36 inches high I would agree that a (minimum) of 5 preferably more are required per foot of width.
    As for width 4 to 6" wider than the tractor is the minimum.
    90cummins
  9. #19
    Gold Member
    Join Date
    Aug 2011
    Posts
    430
    Branson 4720
    Ok I see now how you did it. Might have to beef it up for a frozen driveway end from the road plow.
  10. #20
    Join Date
    Nov 2012
    Posts
    82
    N. Illinois
    L4610 GST/ LA 852 loader, GrassHopper 725DT
    Not to hi-jack this thread but "Doxford Jim" where can one buy the "extension wings" like you have.................. the yellow ones look like perfect size to expand my 30 + year old J.D. 666 snow blower (looks similar to yours).
    Carl (Thanks so much)!
    Attached Thumbnails Attached Thumbnails Snow blower width-dsc01318-jpg   Snow blower width-dsc01320-jpg
Similar Threads
  1. Rear snow blower or front mounted snow blower
    By Doc_Bob in forum New Holland Buying/Pricing
    Last Post: 10-29-2012, 01:04 PM
  2. Loader Snow Blower just isnt right. Blower is a blower, right?
    By Searay45DB in forum Kubota Owning/Operating
    Last Post: 04-14-2011, 11:44 PM
  3. Replies: 8
    Last Post: 09-08-2010, 03:52 PM
  4. width of toolcat blower
    By dylan in forum Toolcat
    Last Post: 09-22-2009, 10:11 PM
  5. Snow Snow Blower Width?
    By Scotty in forum Kubota Owning/Operating
    Last Post: 08-15-2000, 01:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
