Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Veteran Member vtsnowedin's Avatar
    Join Date
    Jul 2011
    Posts
    1,802
    Default Re: Thinking of buying tire chains. What is your opinion and experience?
    Quote Originally Posted by Coyote machine View Post
    vtsnowedin, those are 'Talons', right? I don't see where you mentioned what the chains are you're running.
    I've got Aquiline MPC chains on the rear of my Kioti, low profile for not a lot of fender clearance, not quite as aggressive as Talons, but more aggressive than duos. they use a flat bar on each link for gription and won't drop between the lugs on R4s.
    I scored these on CL for $350 so I not sure weither these are Talons, Valbys or Norsk brand. I think all three are made on identical machinery as far as I can see. The local dealer in Barre VT gets $1100 for a new set this size and they are worth it new or used.
  2. #12
    Super Star Member RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    18,045
    Bethel, Vermont
    John Deere 4400 MFWD, Deere 855D UTV and assorted implements
    Quote Originally Posted by Gasifier View Post
    Anyone have experience with tirechains.com?
    I bought my chains from them. Since you're in NY State, shipping shouldn't be too bad...give 'em a call and you'll get all the costs.
    Now, it's possible they may be out of stock for some types of chains by this time. But you can be prepared for next winter!
    Roy Jackson
    "Any government that does not trust its citizens with firearms is either a tyranny, or planning to become one."
    -Joseph P. Martino
  3. #13
    Join Date
    Jan 2008
    Posts
    730
    Western PA
    John Deere 5083E MWFD, Kubota L3400 HST
    I bought the duo-grip v-bars and I would suggesst the cross chains. The spacing in the patterns caused me to do some home modifications. They would much better now, although I took a slide the other day and im considering something with v-bars for the back side. With r-4's any chains should be fine since the tread isn't nearly as deep as R-1's. I personally prefer v-bars for the longer wear (not that i have ever worn a set out) but if i'm spending money I want some traction.
    '11 John Deere 5083E, 563NSL Loader, MX10 Mower, 78" Bucket, Forks/Bale spear (interchangeable)
    L3400 Kubota HST Loader, finish mower, rake, scraper blade, Gin pole, Kustom Fab front hydraulic snow plow (Inspired by ASGAR),
    '01 International 4700 LP, DT530, Allison MD3060, Air Ride, Crew Cab
    '11 Moritz 20+5 14.5K GN with adj. Tail
    '95 CR 500
    FIL-JD 4020; Ford 9600,5000
  4. #14
    Bronze Member Gasifier's Avatar
    Join Date
    Jan 2012
    Posts
    93
    St. Lawrence River Valley, N.Y.
    2005 Bobcat B300 T.L.B.
    Quote Originally Posted by RedNeckRacin View Post
    I would like the Duo-ladders with v-bars or the talons but man are they expensive. Can't decide if I should wait until I have enough money saved up for one of those or go ahead and buy the duo-ladder combos. For what I do I think the duo-ladder combinations would be enough for me. I am not a farmer, I just use my tractor for hauling wood, plowing snow, moving material, ditch work, etc., but these things are not my regular job.
  5. #15
    Elite Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    3,857
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    If it were me I'd wait and buy before next winter. It's March 1st already! Yeah! You won't regret buying the best you can afford, and some chains like mine are better for plowing than they are for mud or in the woods. The Talon type vtsnowedin has on his Deere are the top of the line, and you will see those type chains on skidders, etc.
    2010 DK-40se/hst, Kioti KL-401 FEL, (with reversible Kioti cutting edge), 72" Ratchet Rake. Fit Rite Top-N-Tilt hydraulics & diverter valve. HLA Series 2000 7' snowplow, Aquiline MPC rear chains.
    Scag Wildcat: Kawasaki 26HP, with bagger system. Dr. brush mower, & 42" lawn deck, Dr. self propelled, 6.5HP Trimmer mower. Pro-Mow 3 gang mower, no HP.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss, '86 anniversary edition.
  6. #16
    Join Date
    Jan 2008
    Posts
    730
    Western PA
    gas, either way you want to go. Chains are a huge improvement over tires in winter/muddy conditions. The only reason I would suggest shying away from the v-bars is if you have paved areas that you are working on (i didn't re-read the thread but i thought you mentioned this.) Actually if you have r-4's Another member and myself debated back and forth quite a bit about the duo's since he had such good luck with just cross chains. My only reason for suggestiing duo's would be if you have tires that will hide a 3/8" chain inbetween the lugs. I dont think there are many r-4's that will even do that.
    '95 CR 500
  7. #17
    Elite Member whistlepig's Avatar
    Join Date
    Jan 2009
    Posts
    3,906
    Preble County, Ohio
    Kubota B7800 with FEL
    I've had these Aquiline Talons a couple of years. They work good for me. When I ordered them it took several months to get them. Seems that the chain dealers order them in the fall and when they run out they don't order any more until the fall of the next year. Thinking of buying tire chains. What is your opinion and experience?-img_0296.jpgThinking of buying tire chains. What is your opinion and experience?-img_0298.jpg
    ........Shoot this thang! Have mercy this thang is killin' me. Just shoot up here amongst us. One of us has got to have some relief..............
    jerry clowers-a coon huntin story.
  8. #18
    Silver Member joeyd's Avatar
    Join Date
    Jul 2010
    Posts
    225
    North Idaho
    TYM 353HST
    I use 4 link v-bars on all four tires (r-4's) and am very pleased. I have a long hilly section of road to keep open and they work well, snow or ice. I don't have any asphalt to worry about and I use osb on my shop floor when I park it inside for the winter. Tirechains.com were the best price for me.
    Isa 43:2-3
  9. #19
    Member
    Join Date
    Oct 2011
    Posts
    42
    Kubota L3400
    Check Tire Chains, Truck Chains, Car Chains and Traction Cables Good prices, free shipping. They have Duos and the tensioners work very well. My driveway is on a hill. Must be 3:1 in places. No problem with et Duos.
  10. #20
    Join Date
    Jan 2009
    Posts
    57
    Maine
    JD 3320 + cab + 300 CX FEL
    I agree that it is handy to have chains with bite (unless you have a paved driveway)...I have always gotten mine from Canadian Chain in Skowhegan Maine Canadian Chains [Agriculture Charts]. The type I have is what they call Agricultural Ladder Type.....they can custom fit these to any size tire,,,Thinking of buying tire chains. What is your opinion and experience?-3320-chain-rear.jpg....they are great on snow, more and ice...useful after an ice storm to "rough up" the driveway.
Similar Threads
  1. Replies: 7
    Last Post: 10-28-2011, 08:26 PM
  2. Thinking of getting chains?
    By vjd57 in forum Kubota Owning/Operating
    Last Post: 10-12-2011, 10:37 AM
  3. Replies: 9
    Last Post: 05-09-2010, 07:45 AM
  4. Chains R4: no clearance for tire chains in L3830; any experience?
    By sevilla in forum Kubota Owning/Operating
    Last Post: 01-03-2010, 12:16 AM
  5. What Tractor for us? Need an experience opinion.
    By ABrown in forum Buying/Pricing/Comparisons
    Last Post: 01-16-2006, 10:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
