Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
  1. #1
    Platinum Member High Compression's Avatar
    Join Date
    Aug 2010
    Posts
    565
    De Soto, KS
    Kubota L5740-3/ Kubota ZD21 pro60
    Default Powered plow wings
    Ok, I know that there is no perfect tool for every application. And generally the more things you try to make a tool fit, the worse is gets at doing any one job well. For example a crescent wrench doesn't fit anything.
    I know my containment plow moves more snow and cleans up trails better. I know that my angle blade opens up long driveways, lanes etc. Both do a decent job back dragging from garage doors.
    I have had fixed wings on many plows before, and loved them. They do get in the way from time to time as well. So, I was wandering, who of you out there have a Blizzard Power Plow, or MachinAbility power side wing, or some other hydraulic powered winged snow plow? What are your thoughts on reliability, efficiency, cost, etc.? How does your tractor handle them? Are they super heavy?
    Oh and I need pix too. We all love pix.
    Powered plow wings-2-23-13-jpg Powered plow wings-2-20-13-jpg Powered plow wings-l5740-1-jpg
    Here's my very first set of wings that I fab'd up.
    Powered plow wings-100_2243-jpg Powered plow wings-100_2430-jpg Powered plow wings-100_2240-jpg
    Powered plow wings-100_2431-jpg Powered plow wings-100_2432-jpg Powered plow wings-100_2435-jpg
    "It is better to be thought a fool, than to open your mouth and prove it."
  2. #2
    Join Date
    Jan 2008
    Posts
    2,413
    Western PA
    John Deere 5083E MFWD, Kubota L3400 HST
    Default Re: Powered plow wings
    wasn't there a power adjustable snow box from a company? Like this one on youtube? Horst SnowWing Incredible snow plow. - YouTube
    '11 John Deere 5083E, 563NSL Loader, MX10 Mower, 78" Bucket, Forks/Bale spear (interchangeable)
    L3400 Kubota HST Loader, finish mower, rake, scraper blade, Gin pole, Kustom Fab front hydraulic snow plow (Inspired by ASGAR)
    JD 550 Dozer 6 way blade and winch
    JD 450B Track Loader
    Case 480C Backhoe W/ Extend-a-hoe
    '01 International 4700 LP, DT530, Allison MD3060, Air Ride, Crew Cab
    '11 Moritz 20+5 14.5K GN with adj. Tail
    ''08 700R Raptor
  3. #3
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,338
    Central Ohio
    Kubota MX5100
    No experience with them but the plow on my wish list is a blizzard speed-wing. Where the trailing edge wing automatically goes straight when fully angled to help windrowing. Cause the only complaint about my fixed wings is that it dont wind row well unless I take the trailing wing off.
    But...to me, it just looked like more cylinders, hoses, valves, wiring, and more moving parts to go wrong.
    Kinda like the KISS theory. Keep it simple stupid.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  4. #4
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    17,498
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
    Nice looking wing setup.
    Light fluffy snow looks like it will darn good,but the heavy wet???
  5. #5
    Join Date
    Aug 2010
    Posts
    565
    De Soto, KS
    Quote Originally Posted by RedNeckRacin View Post
    That's exactly what I'm talking about. But I don't know anyone with one to ask their opion.
  6. #6
    Join Date
    Aug 2010
    Posts
    565
    De Soto, KS
    Quote Originally Posted by LD1 View Post
    I agree totally. I had thought about that as well. But, you can't get very close to a building to back drag because the wings stick forward too far. Otherwise I would just make another set of fixed wings.
  7. #7
    Join Date
    Aug 2010
    Posts
    565
    De Soto, KS
    Quote Originally Posted by Thomas View Post
    Depending on the accumulation, I do just fine. The 14" light fluffy snow was even too much to use the box plow on. I had such a mountain in 20 ft. that I would run out of traction. So I had to stick to the angle blade. But 6" or less regardless of wet or fluffy, I can push the length of a football field pretty easy.
  8. #8
    Join Date
    Apr 2008
    Posts
    18,338
    Central Ohio
    Kubota MX5100
    Quote Originally Posted by High Compression View Post
    I see your point now. I guess I dont pay much attention because I dont have to get too close to things. If I get within 2-3' when backdragging, that is more than enough.
    And even with the design of my back blade, the way the braces and angle fuctions are on it, I can get just as close with my plow and wings as I can with the rear-blade.
    I think they make plows that have fully hydraulic wings where you can run everything straight if you want.....
    But for me, that would turn into just too many buttons on the control I like the simple up down left right
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  9. #9
    Super Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    7,550
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canop
    I have a new HLA/Horst welding 7' plow without wings. It is well designed and very sturdy.
    They make a winged plow that has wings that can go forward OR back for boxblade like forward motion or for backdragging close to doors etc. They probably start at a large size and go up to 20' wing span!
    Check out their site. The plows are AMAZING, but not cheap for what you get.
    2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
    2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
  10. #10
    Join Date
    Aug 2010
    Posts
    565
    De Soto, KS
    Quote Originally Posted by Coyote machine View Post
    Yes they make good looking plows from what I can see on the internet. Unfortunately no dealers here in KC. Maybe I should become one!
Similar Threads
  1. Plow wings for a 60" blade
    By sixgun in forum Snow Removal
    Last Post: 01-29-2015, 07:41 PM
  2. Snow Plow Wings
    By bubbacuse77 in forum Customization
    Last Post: 12-05-2011, 10:23 PM
  3. Snow Plow Wings
    By skidsteer.ca in forum Build-It Yourself
    Last Post: 02-25-2011, 04:56 PM
  4. Snowplow Wings
    By Mech in forum Attachments
    Last Post: 08-03-2008, 05:44 PM
  5. PTO Powered Rotary Plow
    By psj12 in forum Attachments
    Last Post: 01-08-2008, 03:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
