Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Join Date
    Jun 2012
    Posts
    67
    winona mn
    jd2520
    Default Looking to get a 54 inch John Deere snow blower
    Before next winter I am going to get a 54 inch snow blower for my 2720
    Need some input on likes and dislikes and did they ever go back to a steel impropeller?
  2. #2
    Platinum Member jpm1's Avatar
    Join Date
    Feb 2008
    Posts
    590
    Panther Lake, Oswego County New York
    Mahindra 2810 HST, Kioti DK35SE HST
    Default Re: Looking to get a 54 inch John Deere snow blower
    For the past 20 years i have had Buhler/Farm king blowers. I am on my second one now, wore the first on out after 18 years of abuse.I rebuilt the first one 2 times last rebuild the parts were going to cost more than a new machine. Dont be scared by this statement because i was doing 6 driveways at least 2 times a day that were 1500 - 2000 feet long. For normal use this machine will last a life time. Farm King/ Buhler is a good machine with good parts availability and reasonably priced. Heres some pice of mine and the new one. . . . .John
    Attached Thumbnails Attached Thumbnails Looking to get  a 54 inch John Deere snow blower-my-tractor-003-jpg   Looking to get  a 54 inch John Deere snow blower-my-tractor-004-jpg   Looking to get  a 54 inch John Deere snow blower-050-jpg   Looking to get  a 54 inch John Deere snow blower-051-jpg   Looking to get  a 54 inch John Deere snow blower-047-jpg
    Looking to get  a 54 inch John Deere snow blower-my-tractor-003-jpg   Looking to get  a 54 inch John Deere snow blower-my-tractor-007-jpg   Looking to get  a 54 inch John Deere snow blower-tractor-06-jpg
    Lord, Help me to be the man my dog thinks i am . . .John. Mahindra 2810HST, 108H loader with Quick tach buckets and forks. Kioti DK35SE HST with loader, Hyd. top link and second set of rear remotes, 60" and 66" buckets, Kubota 900 RTV and a bunch of other good stuff
    Buy more equipment, It makes life easier.!
  3. #3
    Join Date
    Apr 2011
    Posts
    574
    John Deere 2720
    Quote Originally Posted by logankelly View Post
    I just bought mine last July and it has the plastic impeller. It looks like recent 47" blowers now use the plastic impeller as well. I purchased a metal impeller for mine. I have it here sitting in the box waiting for the weather to warm up again so I can install it.
  4. #4
    Elite Member
    Join Date
    Sep 2008
    Posts
    4,796
    NE USA
    JD LA115, WH 244, Troy Built Horse 8 HP
    It all depends on how much you can afford to
    spend and the horsepower at the power take off.
    You can purchase the next larger snow blower size and have the ability
    to travel faster on the second and further passes using a half cut if desired.
    The Lorenz and Pronovost brands have steel impellers as standard equipment
  5. #5
    Join Date
    May 2008
    Posts
    51
    Durham, Maine
    If you are talking about the front blower from Deere, I have been running the 54in. blower on my JD 2305 and have zero complaints about it. I have never plugged it up and I blow anything that falls here in Maine. Dry snow, corn snow, wet, slush, water, anything and it just blows it. If I keep feeding it enough, it doesn't plug. I was also concerned about the composite impeller when I bought it. If I had one with a metal impeller, I would probably change it for the composite one. Nothing sticks to it. After six winters and blowing small rocks, sand, mud, etc., there is not even a nick on the impeller. This front mounter JD blower is a good rugged machine. The only thing I added was the cable raise and lower the deflector on the chute. It also blows quite a volume of snow and at a surprising distance. I have no regrets about the blower or the composite(plastic) impeller fan.
  6. #6
    Gold Member North Country's Avatar
    Join Date
    Apr 2011
    Posts
    368
    VT
    John Deere 2305
    Quote Originally Posted by leonz View Post
    Why would you pay for a bigger blower, then intentionally take small cuts?
    JD doesn't make a larger size for the 2720. You'd have to go to another brand, but I don't think anyone makes a wider front-mount one that will bolt directly onto a 2720 for less than double the price of the 54" JD.
    NC
    My hills have hills.
  7. #7
    Join Date
    Apr 2011
    Posts
    574
    John Deere 2720
    Quote Originally Posted by Robert F. View Post
    Your experience has been different than mine. I have a gravel driveway which I have been clearing with various snowblowers for 25 years. I just bought the 2720 and 54" blower in July and we had virtually a non-winter. As a result I mostly cleared snow with the rear blade and only got to use the blower for around 2 hours. My plastic impeller already has a lot of battle scars to the extent that it has me wondering how long it will last. I am very good at minimizing the gravel that it picks up. I have the shoes adjusted to around 2". By comparison, my 13HP 33" MTD walk-behind snowblower is almost 15 years old, has handled countless brutal winter snow falls, has a metal impeller the same size as the 54" JD and other than some paint missing it looks like the day I bought it.
    Unfortunately I wil lnow have to wait for next winter to report if my new metal impeller in the 54" blower works better than the plastic one.
  8. #8
    Join Date
    Jun 2012
    Posts
    67
    winona mn
    jd2520
    is your metal impeller a John Deere part or a after market item?
  9. #9
    Join Date
    Apr 2011
    Posts
    574
    John Deere 2720
    No, it is the JD OEM part for the 47" blower - which several forum members have used as a replacement. If I recall, the part number was AM109105.
  10. #10
    Elite Member
    Join Date
    Sep 2008
    Posts
    4,796
    NE USA
    Quote Originally Posted by North Country View Post
    A number of the members on the forum have blowers larger than what
    their mules can power, they simply clear snow at slower pace in reverse
    The idea is simply that you may have a smaller tractor but a wider
    snow caster will clear the lanes at a slightly slower speed with no difficulty
    as the entire cross auger is used against the snowpack and the gear reduction
    on the snow casters cross auger and impeller operates with no difficulty.
Similar Threads
  1. John Deere 44 inch snow blower
    By leonz in forum John Deere Lawn & Garden
    Last Post: 01-03-2013, 11:14 PM
  2. Buying Advice Snow blower for John Deere 3720
    By Forrest1357 in forum Buying/Pricing/Comparisons
    Last Post: 12-16-2012, 12:45 PM
  3. 54 inch john deere snow plow wear edge
    By Yellowfever440 in forum John Deere Lawn & Garden
    Last Post: 01-05-2012, 07:07 PM
  4. 54 inch john deere snow plow wear edge
    Last Post: 12-12-2011, 10:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
