Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Default Re: Snow Blower dolly
  2. #12
    Elite Member JerryK's Avatar
    Join Date
    Feb 2004
    Posts
    2,781
    Vanderbilt, Michigan, USeh?
    Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154S
    4 Each Heavy Duty 6"x 2" Trash Bin Swivel Caster Rubber Zinc Plated Steel Frame | eBay
    Set of four 6" X 2" Heavy Duty [ 500 lbs each ] solid rubber covered cast swivel casters, $ 44.99 including shipping on Ebay... As with all swivel casters, make sure you make the base wide enough to keep it from getting tippy whilst the swivels are a swiveling...
    78" [26"X10"fan] Mahindra front blower,72" Mahindra front blade, 48" CID QA forks, 6' EverythingAttachments Land Plane & Landscape Rake, 78" JRW rear blower[26"X8"fan], homemade 1 ton rear weight, 6' Ford rear blade, big homemade 3pt box/carrier, 8" wood chipper
  3. #13
    Join Date
    Mar 2011
    Posts
    643
    Florida Ma.
    Ford 1720 SSS 4x4 Turbo Charged
    I bought a used pallet jack and keep the seasonal attachments on pallets in my garage.
    Very easy to maneuver and the pallets are free.
    I removed the boards on 1 side so the jack rolls easily underneath.
    I also modified my cabinets and 40 ton press so they can be easily moved.
    Occasionally I work on large pieces and need to move my press into the middle of the garage for access.
    I would say the jack was one of my better purchases.
    90cummins
  4. #14
    New Member
    Join Date
    Jan 2013
    Posts
    23
    Dover, ID
    Massey-Ferguson 253
    Thanks 90cummins, I sure appreciate all the ideas and options for moving this thing around. I don't really like the idea of leaving the blower outside, guess I wasn't raised that way. The fact of being able to keep it under cover, move, store it and hook it up easily is very important to me.
  5. #15
    Join Date
    Feb 2004
    Posts
    2,781
    Ended up using my two sets of Ebay casters to make a big 60" by 40" cart for my steel collection and one for my chipper. Maybe snowblower, next time....
  6. #16
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,994
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Here is a good source for casters: https://www.surpluscenter.com/sort.a...s&keyword=TCPL
    I made a three caster dolly for my tree puller. I had one heavy duty caster that was an inch and a half shorter than the other two, so I was able to do it with two boards!
    Snow Blower dolly-p6210036-jpg Snow Blower dolly-p6210037-jpg Snow Blower dolly-p6210039-jpg
    Tree Puller thread: http://www.tractorbynet.com/forums/a...ee-puller.html
  7. #17
    Veteran Member The Fred's Avatar
    Join Date
    Jun 2013
    Posts
    1,007
    hOOterville
    Couple of Orange Clunkers
    Have you thought about mounting zero turn front wheels on a retractable frame to work with a rear remote? I don't think they need to swivel. If you mount them close to the center of gravity of the device it would roll around easily and be used for gauge wheels on your stone driveway.
    Fred
  8. #18
    Join Date
    Jun 2013
    Posts
    1,007
    hOOterville
    Snow Blower dolly-imgp0110_zpse3c0f902-jpg
    Landing gear from a Cessna 150.
    Here's what I did, works well on the lawn and small stone yard. Pushes around the shop perfectly by hand.
    Need snow to try it out, and paint. This wasn't cheap and took many hours of fabrication, too much in fact.
    Rockshaft cylinder has 3 inch stroke from John Deere MMM. Wheels from a Toro commercial ZT mower.
    Fred
  9. #19
    Gold Member duroc's Avatar
    Join Date
    Feb 2012
    Posts
    340
    Michigan
    NH T1510 HST
    All good ideas and very nicely done!
    My blower stays in the shed during off the season, but shares the winter months in the garage with my truck. I'm limited for space and using a dolly of any kind takes up too much room. So, here's how I did mine...
    Picture (1) I removed the skid shoes, drilled 2 holes and welded 2 bolts (minus the heads) from the back side.
    Picture (2) I used trailer leaf spring hangers that I've had lying around for years. Cut them down and welded the removed section on the backside of the hangers. This allowed the wheel hanger to be moved outboard because the foot of the shoe hangs outboard of the vertical mounting portion (as shown in pic. 1). The notch in the hanger allows me to mount the wheel/hanger when the skids are in either of the 3 height positions. I drilled the wheel stud hole off center so more weight of the blower would be shifted towards the front single wheel, this helped control the blower balance.
    Picture (3) shows the completed wheel asm mounted.
    Picture (4) shows the front wheel leg and bracketry made and installed. This assembly stays with the blower while in service and pins up like any other "kickstand" would.
    Picture (5) shows total completion
    The removal/installation of all 3 wheels takes about 30 seconds once the blower is hooked to the 3pt., and the wheel/bracket assembly's only take up a shoebox space on/under my work bench.
    Attachment 343983Attachment 343984Attachment 343985Attachment 343986Attachment 343987
    "If con is the opposite of pro, is Congress the opposite of progress?"
  10. #20
    New Member
    Join Date
    Jan 2013
    Posts
    23
    Dover, ID
    Massey-Ferguson 253
    Great Job Duroc! A very professional looking job. I just took delivery of my 75" Martin Meteor yesterday. Excellant application to use on my blower! Thank you!
    degerb
Similar Threads
  1. Snow blower snow chute w/ linear actuator
    By Carl Bert in forum John Deere Lawn & Garden
    Last Post: 02-15-2013, 04:00 PM
  2. Rear snow blower or front mounted snow blower
    By Doc_Bob in forum New Holland Buying/Pricing
    Last Post: 10-29-2012, 12:04 PM
  3. Loader Snow Blower just isnt right. Blower is a blower, right?
    By Searay45DB in forum Kubota Owning/Operating
    Last Post: 04-14-2011, 10:44 PM
  4. Replies: 8
    Last Post: 09-08-2010, 02:52 PM
  5. Grading Anybody make a dolly and jig to support BX2763A HD dozer/Snow Blade?
    By shrekbelly in forum Kubota Owning/Operating
    Last Post: 08-19-2008, 11:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
