Results 1 to 10 of 17
03-04-2014, 12:56 PM #1
- Join Date
- Nov 2013
- Posts
- 7
- Location
- Post Falls, ID
- Tractor
- Kubota L5740
Quick tach truck plow conversion with lateral float
I have a 2 mile gravel road that I plow with a lot of turns, hills, switchbacks undulation, etc... I read a lot of the prior posts and input so this is what I came up with. I waited until spring to find a cheap plow on CL, luckily I had it done and was able to use it on this last dump we got of 8". Worked great, very happy with it. Thought I would give back a little to the forum if there is anyone else that is looking to do a conversion plate.
03-04-2014, 02:35 PM #2
- Join Date
- May 2008
- Posts
- 673
- Location
- Santa Claus, Indiana
- Tractor
- LS XR4046HC, New Holland Boomer 1020
Re: Quick tach truck plow conversion with lateral float
Looks great! I'm looking for a cheap plow to make one myself. We normally don't see a lot of snow here, but this winter has me wishing I had one in the barn.
1 cross + 3 nails = 4given
Write with chisel when I'm gone, "Return to sender" on my stone.
LS XR4046HC, hyd top link, 22" 120W LED light bar, Titan bale spear/60" pallet forks, Land Pride 72" brush hog, King Kutter 72" box blade, Woods 60" rear blade, King Kutter 60" tiller, and one heavy ballast box
http://www.santapawspetpark.com
03-04-2014, 02:53 PM #3
- Join Date
- Sep 2009
- Posts
- 3,337
- Location
- Flushing, Michigan
- Tractor
- Kubota B2620 with BH65 backhoe, Ford 2N
I have been trying to figure out what lateral float is. Now I think I get it. It's the pivot on the round stock in the bottom of the attachment, right?
03-04-2014, 03:27 PM #4
- Join Date
- Nov 2013
- Posts
- 7
- Location
- Post Falls, ID
- Tractor
- Kubota L5740
Yes, it allows the plow to follow the road independent of the tractor. One of the issues with a plow on a FEL is that it is further out from the front wheels than it is on a truck and the front end of a tractor doesn't give near as much as the suspension on a truck. You end up having the edges of the plow dig into the road more when the road isn't flat, or if it is frozen hard the plow rides up and leaves snow in the lower areas.
03-04-2014, 03:39 PM #5
- Join Date
- Jun 2012
- Posts
- 310
- Location
- grain valley mo.
- Tractor
- farmall 40
Todd3773. Are those plow wings your design? Your mount looks great. Do you have trouble when the blade is turned, sliding the front wheels? lt190b
03-04-2014, 03:51 PM #6
- Join Date
- Sep 2009
- Posts
- 3,337
- Location
- Tractor
Thanks for posting. Nice piece of equipment.
03-04-2014, 04:12 PM #7
- Join Date
- Nov 2013
- Posts
- 7
- Location
- Post Falls, ID
- Tractor
- Kubota L5740
Plow is a 7.5' Meyer, wings are also Meyer wings. It adds about 20" to the overall width. With the chain I can keep the A-frame of the plow off the ground about 6" and therefore the FEL arms are suspended which puts their weight on the front tires. I use the bucket tilt to raise and lower the plow with the chain. It really works well. I have loaded tires and h-chains on the rear only. No stearing problems, only issue I have is traction when pushing a lot of snow up a steep incline. I have a spreader on the back I use to sand the road which is light. I have tried to keep it loaded with sand but it then freezes in the spreader.
03-04-2014, 04:18 PM #8
- Join Date
- Nov 2013
- Posts
- 7
- Location
- Post Falls, ID
- Tractor
- Kubota L5740
Thanks GP.
03-04-2014, 04:58 PM #9
- Join Date
- Jun 2012
- Posts
- 310
- Location
- grain valley mo.
- Tractor
- farmall 40
03-04-2014, 05:13 PM #10
- Join Date
- Nov 2013
- Posts
- 7
- Location
- Post Falls, ID
- Tractor
- Kubota L5740
Similar Threads
Bob-Tach, Quick-Tach, Heart-A-Tach which is which?
By Lockport in forum AttachmentsReplies: 12Last Post: 05-24-2011, 09:59 AM -
Grading 4100 plow blade quick tach/loader arms?
By acs55812 in forum John Deere Owning/OperatingReplies: 13Last Post: 12-23-2008, 08:24 PM -
Quick-Tach, Fast-Tach, Skid Steer - Same Thing?
By GaryBDavis in forum AttachmentsReplies: 4Last Post: 12-13-2004, 02:29 PM -
Quick-Tach/Bob-Tach mechanism dimensions??
By uhmgawa in forum Build-It YourselfReplies: 0Last Post: 05-21-2003, 04:33 PM -
Lateral Float
By RobS in forum John Deere Owning/OperatingReplies: 5Last Post: 04-01-2001, 08:21 PM
