Rustyiron
Super Member
Finished this today. It has about 15 deg. of horizontal "swivel" built in for un even ground. The square bar that you see going from high on hitch side to low on the plow "A" frame telescopes about 6" so that the plow can either "float" as it would on a normal truck, or tilt the hitch forward to the end of this 6" stroke and apply down pressure for extra scraping. Rolling the hitch back towards the tractor, this will reach the other end of it's travel and is used for lifting off the ground. I'll paint the actual blade next spring when it's a little warmer for outside painting. That blade is a 9' Diamond with a cutting edge trip design. I bought it from the next town over for $225 and the angling cyls. and cutting edge were missing. The next "project" is frame mounting a Fisher 9'6 "Vee" to the tractor! Also from the same neighboring town.:thumbsup:
