Thanks again for the additional advice!
I called my Kubota dealer today to inquire on rear 3-point snow blower for my BX25. I did this mainly as a pricing point and to pick their brains a bit but, was very surprised by their response. In most cases, they usually do not recommend Kubota 3-point snow blowers. This seems to align with one previous post that suggested the Kubota offering might be sub-standard vs. others available. The dealer recommended a Bur-Vac Blizzard 48 snow blower and after looking at Bur-Vac痴 specs, I am in agreement that 48 is likely preferred for my tractor vs. the larger 54 model. The 48 model has a 20 fan diameter and the 54 has a 24 fan diameter?o there is a definite impeller difference and it痴 not just a wider blower. At any rate, the dealer is working up a quote for me that would include both hydraulic chute rotation and deflector.
Any opinions on Bur-Vac as a brand in general?I will search the forum but, thought I would ask, as I致e never heard of them before.
I believe the Blizzard, Frontier and Kubota rear mount snow blowers are made by RAD out of Canada, and these blowers are all identical except for color.
At least a couple of years ago that was the case, I just looked at some photos of some new Kubota rear mount blowers, and from what I can see, it's the same as my Frontier.
I can't find any photo of a Blizzard snow blower, but I did see a new one locally 2 years ago and it was the same as my Frontier.
Just look them over and see if you can see any differences.
Here is a link the the John Deere Frontier snow blowers.
https://www.deere.com/en_US/docs/pdfs/frontier/DSFE51007_frntr_snowblwr_3pt_v2a_lr_sngl_pgs.pdf
If you look at the spec page the SB1154 has a recommended Min 16 pto HP - Max 35 pto HP
Your BX25 has 17.7 HP so you are 1.7 HP over the Min 16 pto HP
My Kubota B7800 has 22 pto HP the Frontier SB1164 blower I have has a recommended Min 20 pto Hp - Max 50 pto HP
so I am only 2.0 HP over the Min 20 Pto HP
As I mentioned in my earlier post, I can blow snow over 35'.
With the HST trans on your BX25, if the snow blower starts to bog down, you just slow your ground speed and allow the pto speed to get back up to normal.
I don't think you'd have any problems with the 54" snow blower.
I really believe it would be more advantageous to have the 54" with the bigger 24" impeller with the 26" high intake than the 48" wide with the 20" impeller and 24 " high intake.
Good luck
EDIT
Here is a video of a BX25 with a 6 foot RM snow blower.
http://www.youtube.com/watch?v=2lwiR2W2GnM
