Leon: Thanks for the in-depth response! I looked at the machines you recommended. That rear snowcaster is quite the tool - simply amazing. The problem is arthritis - no way in the world can this old War Horse drive a JD or any tractor twisted backwards. Thanks for you time though - much appreciated.
As much as I dislike them you can a get a front mount snow caster for
the JD 1023E and the Kubota 2370 as well and a nice all weather cab.
One of the bad things is that the front mounts are horrible with deep snow
because they behave just like the walk behinds and have problems with
deep snow.
Many of the members here simply turn sideways in the seats and are able to
watch the rear as they work clearing snow. the majority of the swivel seats
can replace the standard seats on both brands of mules.
You will definitely need front chains with your purchase as well.
You should also examine purchasing a larger frame size mule/larger power range
in the 50 to 75 horse power bracket as they have the upgraded seats that swivel
and have the comfort cabs.
With the swivel seats and the open station tractors you have plenty of room to turn and
also watch watch whats going on in back with comfort(which is why the swivel seats were designed
for watching corn choppers, hay balers, rakes etc. to reduce neck strain and twisting.
JUST SO YOU KNOW, the front mounts cannot be purchased with "chute extensions" to aid in
casting snow further and to prevent snow blowing back on you.
ALSO I want you to understand that you can purchase a rear mount snow caster and have it mounted in the front
of a four wheel drive tractor that has a mid mount power take off and by purchasing a front mount kit from a
pronovost dealer I believe that there still are two or three Pronovost dealers in Maine so getting set up with a front
mounting kit and one of their snow caster will not be an issue.
For the money spent you will be better off as the front mount system can be left on the mule the year round.
As long as you buy 25 -50 horse power mule with a mid mount PTO you can do this and avoid spending extra money
on a skid steer loader with a hydraulic snow caster .
I want you to succeed and not fail. do not let the dealer talk you into a front mount for the compact utility tractors if you
upgrade to the larger frame size of mule
I will tell you that with all plumbing and controls under the seat and the foot boards of all the skid
steer loaders are something you will not be able to work on and the labor rates are awful.
I will tell you that we have many members that have the smaller 2 wheel drive garden tractors with the front mount snow casters.
but you will need good V bar snow chains and have the rear tires loaded with windshield washer fluid for
ballast.
The fabric cabs available for them are not substantial and you cannot get heat in them or wind shield wipers.
Many members use insulated coveralls and motorcyle helmets and yellow lens ski goggles to clear their driveways to prevent glare
during the daylight hours.
I want you to at least read the snow removal forum before you go any further to help you understand this before you make a mistake you will regret as I said many members also have installed the swivel seats in the smaller kubotas and use thier rear mounts with no issues with neck strain and they work in thier short sleeves when clearing snow.
I have to leave the keyboard now but I will be back.
