I'll be buying a new tractor before the snow flies primarily for snow removal use--probably Kubota B2601 or L2501. Loader bucket on front; 3pt pto snowblower on rear; front mount blower too complicated and too expensive, imho. I'll be blowing the snow from from about 100 feet of crushed stone driveway--like coarse sand--and from paths across frozen mown fields to various outbuildings. We experienced Maine's coldest and third snowy-est winter on record this last year and I had to wade across a six foot drift all winter because my trusty walk behind blower just couldn't keep up--never again. So, questions:
1. Is 20 pto hp enough for 64" 3pt snowblower? Is 20 enough for a 51" blower? (Kubota L2501 or B2601.)
2. Will a 3pt blower power through frozen, crusty, week-old snow? (As a walk-behind decidedly will not.)
3. R4's without chains or turf with chains?
4. Engine block heater required? Coolant heater required? Any other starting or running cold weather equipment required? (Winter in coastal Maine. Lows to -10F. Third snowiest winter on record last year; snowstorm twice a week for two months.)
5. How stable is a 4X4 tractor, FEL on front/blower on back, backing through 2 feet of snow across gently sloping frozen fields? (Planted solid or Nantucket sleighride?)
6. Kubota snowblower or third party? (Can I do better cost-per-value by not buying the SB with the tractor?)
7. Any other advice appreciated, thanks.
1. It all depends on your wallet, what your time is worth, and how much time you have.
a. many of the members have wider snow casters with smaller mules and
do not worry about how much time it takes as they can take half cuts
after opening the first pass.
b. you need at least 2 sets of rear remotes for hydraulic chute and spout control-
you will be glad you bought those options.
2. Yes it will; Saying that the new Yamaha track drive snowblowers are also
a kick *** walk behind snow caster with glowing reviews. They will cut
through packed snow and their weight will prevent them from riding up
on the snow pack. You would have to cross the border to buy one in
Ontario Province and bring it back to Maine.
3. Loaded rear turf tires with Windshield washer fluid for
ballast as it costs less,
you can fill the rears yourself with a fill valve from Gemplers.
a. 2 link V bar chains-2 link means the cross chains are separated two links apart
b. chain tensioners.
c. Snow Chains have to be installed properly otherwise you are in big trouble and screwed big time when you throw
a chain.
4. yes an engine block heater is a good idea even with the mule parked inside. A salamander is also a plus as
it will heat the ENTIRE tractor up quickly as you will have cold hydraulic and transmission oil to deal with otherwise
a. The coolant heater and the salamander are all you need- if you have a space heater great you have the problem licked.
Your going to want a salamander if you fo not own one to melt the ice and snow to prevent issues of stuck impellers-
using it before you start or after you finish clearing.
b. purchase a Racor diesel fuel filter system for the mule as the Kubota filters plug up and freeze and its another case of
being behind the 8 ball when it dies on you and you have to change the filters where your mule stops. The Salamander
will not prevent the cheap filters from freezing on you.
c. you will need to use diesel fuel treatment for the fresh fuel. A water separator filter from racor is also a good investment
as both the plastic and metal fuel cans are moisture magnets.
5. very stable, you need to put weight in the bucket(sand or solid concrete blocks) for more ballast and traction for the front end.
6. Pronovost(1) Lorenz(2)Allied Farm King(3) Kubota units are made by RAD and I own a green one and they are
)(*&^%$%^&*(. YES I am fussy as I hate changing shear pins when I am clearing land with mine!!
Pronovost and Lorenz have more options, The pronovost P540, P620 models have an extended chute option(semi industrial)
to keep the snow out of your face.
You will be better off buying in the summer as they are impossible to get in the spring fall or winter.
Just remember I do not have my hand on your wallet; and when they start blinking their eyes when
you start asking questions about the mule or thier branded snow blower using my suggestions WALK AWAY
with your wallet in your hand and not in your pocket.
7. send me a PM if you have more questions. Look at the bigger Yamahas as you will be able to buy 3 of them for the cost of a mule and a rear mount.
