aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 18,078
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
I have a front mount blower that I bought last winter. Will be mounting it on our L3830, but I am debating how to control it.
The L3830 has one hydrualic remote (with float).
The blower will have a cylinder to lift it, and it currently has a hydrualic motor to rotate it.
I would like to be able to control lift, rotation and chute angle (I have a linear actuator to control chute angle).
I see a couple of options to control lift/rotation:
Option 1: Use a joystick valve to end up with a handle sort of like on the B2920, but starting on the floorboard or next to the seat:
This:
But mounted where this hole is (or next to the seat):
Price: Between $250 and $450 (guessing).
Pros:
Neat, easy to use, intuitive, could be used for other things in the summer.
Cons:
Expensive.
Option 2:
Use an electric splitter on the existing remote so you flip a switch to choose if you want to rotate the chute or lift the blower.
Price: $150-200
Pros: Neat, cheap, could be used for other things in the summer,
Cons:
No float for the lift when rotating, could be hard to keep track of which mode its in.
Option 3:
Add a 2nd OEM remote.
Price: $400-600
Pros:
Neat, easy to use, intuitive (not quite as easy as the joystick), could be used for other things in the summer.
Cons:
Expensive
Option 4:
Replace the motor with a winch (I have a small HF winch and winch controller that could work) and use a toggle switch or a joystick to control it. Lift would be controlled by the rear remote.
Would use PowerPole (or similar) connectors to connect the winch to the battery, a 7 pin connector
Price: $50-75
Pros:
Neat, easy to use, intuitive (if I do the switches right), I have almost everything in stock
Cons:
Will it be durable?
Here is what the blower chute looks like:
Anyone used any of these and have an opinion?
Thanks
Aaron Z
This:
Pros:
Cons:
Expensive.
Option 2:
Price: $150-200
Cons:
Option 3:
Price: $400-600
Pros:
Cons:
Expensive
Option 4:
Price: $50-75
Pros:
Cons:
Will it be durable?
Thanks
Aaron Z
