Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
  1. #1
    Member
    Join Date
    Aug 2016
    Posts
    44
    North Idaho
    Kubota L3901
    Default Chains on front tires for pushing snow
    Is it a good idea to use chains on the front tires (with chains on the rear tires) when using a front snow blade? Would it put too much stress on the less robust front drivetrain? When I have the snow blade angled a lot, the tractor gets pushed sideways so would front chains help some with keeping the tractor going straight? Thanks!
  2. #2
    Elite Member
    Join Date
    Oct 2006
    Posts
    4,308
    Ohio
    GC2310,
    Default Re: Chains on front tires for pushing snow
    The angle of the blade, as you have noticed, is the key.
    Angle it less, and you're able to go straight.
    I don't believe chains will make much difference.
    You need weight, and friction to over come the side forces that turn the tractor.
  3. #3
    Join Date
    Sep 2011
    Posts
    1,454
    vermont
    Hurlimann 435, Fordson E27n, Bolens HT-23
    I tried chains up front. Not a big improvement on the side push. great for going forward though. I worried about the drive line stress so pulled the chains,preferring not to deal with them.
    I did discover that judicious application of the plow lift cylinder can put a lot of weight onto the front tires and restore much of the steering control. Not hard to do!
    I also favor a few rows of those screw in studs. They help on ice in many ways.
  4. #4
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    6,636
    Central Square, NY
    LS XR3037HC
    Welcome to TBN..............................
    I use chains front and rear. Rear chains are standard 4 link ladder. Front chains are V bar. They do help steering by biting into the snow and ice. As Ray said, Less angle on the blade helps too. You don't need much angle, just enough to make snow go off the angled side of the blade. Rear tires are also loaded. If at all possible don't use the float mode on the loader and just lower the plow blade so its just off the surface. That keeps the extra weight on the front tires. It all depends on the snowfall we get. Last season was pretty light so I never even used the chains. I don't believe having front chains will cause any extra stress on the drive line because you are still going to have slippage on snow or ice. It may be a problem on blacktop.
    Attached Thumbnails Attached Thumbnails Chains on front tires for pushing snow-dscn1411-medium-jpg
  5. #5
    Veteran Member Sawyer Rob's Avatar
    Join Date
    Dec 2014
    Posts
    1,727
    Upper Mid West
    several brands
    I won't run them on the front of my tractors, those front end parts just aren't built heavy enough for me to take that chance!
    SR
  6. #6
    Member
    Join Date
    Aug 2016
    Posts
    44
    North Idaho
    Kubota L3901
    Thanks for the great info everyone! So I guess I won't be putting on my front chains this winter. It's enough work putting the back ones on anyway.
    So I'll put some ballast on the front of the tractor. Do you think 100 lbs of lead shot would be of any help? I've been using float mode since my gravel driveway isn't that smooth. I just ordered one of those EA land levelers to try and get my gravel driveway as smooth as possible. Would not using float make a big difference?
  7. #7
    Join Date
    Feb 2005
    Posts
    6,636
    Central Square, NY
    LS XR3037HC
    Quote Originally Posted by oldafretired View Post
    Just my opinion, my driveway is gravel too and float mode puts the plow on the ground taking all that weight off the front axle. I found if I drop the blade to the ground then pick it up just a little (maybe an inch or less) the weight stays on the axle and tires for better traction and less gravel gets plowed up that I have to rake back off the grass in the spring. I don't mind driving on an inch of snow in the drive. Later in the snow season when the ground is frozen I can then use float mode and it won't dig up as much gravel..
  8. #8
    Elite Member 4570Man's Avatar
    Join Date
    Apr 2015
    Posts
    3,542
    Crossville, TN
    Kubota L3240, Kubota B7100, Kubota F2560, John Deer, F525 Mule 600
    Default
    Thanks for the great info everyone! So I guess I won't be putting on my front chains this winter. It's enough work putting the back ones on anyway. So I'll put some ballast on the front of the tractor. Do you think 100 lbs of lead shot would be of any help? I've been using float mode since my gravel driveway isn't that smooth. I just ordered one of those EA land levelers to try and get my gravel driveway as smooth as possible. Would not using float make a big difference?
    Sell that lead shot and buy concrete or something else cheap instead. Shot was as high as $2 a pound, but it's came down to around $1 or a little more.
  9. #9
    Member
    Join Date
    Aug 2016
    Posts
    44
    North Idaho
    Kubota L3901
    Quote Originally Posted by George2615 View Post
    OK. I'll give that a try.
  10. #10
    Member
    Join Date
    Aug 2016
    Posts
    44
    North Idaho
    Kubota L3901
    Quote Originally Posted by 4570Man View Post
    The lead is ballast for my race car so I need to keep it.
Similar Threads
  1. Chains Chains on front tires only VS. rear only
    By Wyld Bill in forum Owning/Operating
    Last Post: 02-15-2015, 08:02 PM
  2. Will Leaving snow chains on damage my tires?
    By EquineNetworkCO in forum Owning/Operating
    Last Post: 10-20-2011, 10:34 PM
  3. Front Snow Chains on 2520
    By BethesdaEC in forum John Deere Owning/Operating
    Last Post: 12-26-2010, 09:25 AM
  4. chains for front tires 8-16 bar tires
    By sal64 in forum Parts/Repairs
    Last Post: 10-15-2010, 08:29 PM
  5. Chains Chains for BX front turf tires
    By fish6942 in forum Kubota Owning/Operating
    Last Post: 12-11-2007, 06:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2016 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
