fitterski
Gold Member
- Joined
- Oct 20, 2016
- Messages
- 377
- Location
- Nouvelle, QC
- Tractor
- 1987 Cat-426, 1991 Deutz-Dx-6.05, 2019 Husqvarna 2xHP
Reading through this, I started thinking, are dry snow and wet snow enough different that you need different fan for each? or is it simply a different fan speed that would allow you to blow both effectively.
If you are using a hydraulic motor, can you vary the speed? If you slow the fan down, will the auger be too slow? Perhaps you need two hydraulic motors, one on auger, one for fan and figure out the right speeds for the conditions.
Maybe ground speed determines auger speed while type of snow determines fan speed??
Just thinking outloud.. wishing you the best.
Thanks, I always need confidence
It all comes down to HP, how many tons can your engine push vertically to what height per minute. Once you have that you just have to stay on the short side or your engine will stall, maybe make some expensive noises too. I can't give you all the answers, I'm studying full tilt, but I can tell you that wet snow IS like water, in fact a local maverick fabricating family take their $45k rigs to a boat ramp in open water for a final shakedown to see if their reputation will hold! 400hp start stalling in 6-8 inches with a nominal 10 foot swath
