You 2 guy's were imho the blower guy's and hoped you'd answer:thumbsup: It's a Loftness blower that I bought 2 years ago and re finished. Mechanically it's cherry along with the sheet metal. IIRC there's maybe 1/2 in fan clearance, I just brought it in the shop to melt off. We're looking at 2' in the next 24 hrs. and I'm gonna need it on some drive's. We've just about run out of room and the banks have some serious ice in them. leonz, I'm just looking to improve my visibility and if I could just keep the dust from occurring or minimized from the top of the spout to the ground I'd be really happy. In use, the dust just billows out of that open face. As you can see, the chute is open completely (bottom to top) on the one side. (in the first pic) Bottom pic is when I picked it up.
It looks brand new my friend, very, very, nice.
I have quick and hopefully easy remedy for your Loftness blower(that is until you add clarences impeller kit to make it so much more powerful to use to cut down the snow dust)
If you can find and buy a couple of those roll up kiddee sleds you can rivet them to both the sides of the chute and the snow will continue to be funneled up to the spout.
(if all else fails a solid plastic sled would work with the bottom facing the snow stream-you will need a lot of tie wraps to hold it in place but that would work in a pinch.
Clarences impeller kit will let you keep a solid stream of snow coming out of the chute and spout and the rubber paddles scrub the impeller housing clean.
For now though a one or two kiddee sleds and riveting them to the sides of the chute will work by concentrating the snow stream and reduce its ability to disperse as it exits the chute and spout.
Short of the roll up Kiddee sled idea perhaps using the polyester coal bags or a super sack or two wrapped around the chute 5 or 6 times and tie wrapped 2 inches apart with the heavy black tie wraps ment for outside use would be worth trying if you have them since it is Sunday.
if your local tractor supply store is like the rest of them they will be open until 8 PM your time and you should be able to find the heavy black tie wraps there.
I will give Clarence a shameless plug here, The impeller is removed in most cases and the paddle extensions are installed after the corresponding holes for the steel that holds the rubber conveyor pieces in place on the impeller paddle.
He has a herd of neat before and after videos from the folks that have bought the kits and installed them on their snow casters.
Some of the folks have removed the chute from their snow casters and installed the paddle extensions that way by blocking the impeller in place and doing the drilling from the discharge hole
I am sorry I am not closer to help you ;^0.
