BoylermanCT
- Joined
- Apr 1, 2013
- Messages
- 1,507
- Location
- Barkhamsted, CT
- Tractor
- Montana R2844, New Holland TC29D, Hustler X-One
Just bought a used Pronovost Puma 64" snowblower. Get to use it for the first time tomorrow, we are expecting 8". I know you are supposed to blow at 540 rpm. On my Montana tractor, 540 rpm is at 2400 rpm. If I want more blowing power, can I run it higher than 2400rpm? I've never had it above 2400 but I am sure it can go higher. The tach goes up to 3000 rpm. Can the engine over-rev, or will the throttle lever stop at full speed, whatever RPM that is?
Engine is a Mitsubishi 4 cyl 1.5L diesel.
