EricMF1635
- Joined
- Apr 11, 2010
- Messages
- 8
Was bush hogging today and my PTO stopped turning. Check level to make sure it didn稚 get knock to neutral but it痴 fine. Any ideas?
According to TractorData, you have electro-hydraulic PTO.
Basically, you select the PTO gear you want and flip a switch to turn it on. What happens a lot during bushhogging is that sticks, heavier brush and whatever can pull the wires under the tractor and cause all sorts of problems.
You may want to give a closer look under the tractor for any pulled wires. Also check the fuses.
