Phillip w
Platinum Member
- Joined
- Jun 21, 2017
- Messages
- 779
- Location
- whiting ks
- Tractor
- allis Chalmers 185 and massey ferguson 1531
Boy, the 30 series tractors seem to have battery/charging trouble. Got a 730 diesel ( the brother to your tractor) and it has similar problems. It is 24v with for 6v batteries. Tried to switch to (2) 12v batteries and did not seem to have the ump to spin it over like it should. You might try to lightly tap on the voltage regulator with say a screw driver handle and see if it starts charging. If it does, you did not fix it, rather discovered your voltage regulator is on its last leg. Time to replace it. I understand alternator way better than generator. You tractor should be gas and gas needs a electric spark to run. With an alternator, if you have the tractor running and pull the battery cable you find out what you got pretty quick. It tractor died, get a new alternator. If tractor stayed running, alternator is good look for different cause. I don't know if that applies with a generator. I will say you generator output seems pretty low. Also a corroded/loose ground or battery cable can cause you not to charge. Hopefully txjim will get in the discussion. He knows John Deere. I don't know if you pulled the generator and took it to say Napa or O'Reillys if the could test it for you. If it does turn out to be the generator, I know an independent tractor repair shop called all brands ag repair. They are probably an hour and a half maybe two hours from you. The are really good, really reasonable and can probably rebuild your generator way cheaper than if you went to John Deere and bought one.
