Chevyboy89
I have a long story, so I decide to sell my Massey 135 diesel because of all the issue's it had. So I sold it and the search begun for a replacement tractor, I found a ford 3000 diesel that I couldn't pass up. I purchased it and wired the gauges and noticed it ran hot per the gauge. It started leaking oil between the head and block and blowing bubbles in the radiator. So I purchased a new radiator, sent the head to the machine shop for a mill and complete rebuild. I thought great problem solved with a new radiator, water pump, thermostat, and hoses. Well, I was wrong, I installed the thermostat with the spring to the head and the temp is borderline hot on the gauge. I cannot see any coolant circulating in the radiator. My question is which way does the thermostat go? I checked 2 parts fische this morning and even had the dealer check as well, it shows the spring side of the water neck. The dealer said he just changed his on his personal tractor with the spring in the head with no issues.
