2006 TN60A 2wd model
   / 2006 TN60A 2wd model #1
snoots
SNOOTS@FUSE.NET
Tried to disengage posi lock like manual suggested by pressing on the brake but then tractor quit pulling.Never heard any poping or grinding just quit moving.Tractor rolls free.Any suggestions Thanks j
   / 2006 TN60A 2wd model #2
No sounds of movement in the differential? Sounds to me like you need to see the exploded view diagram and look for a broken axle, or something else between the differential and the wheel (can't remember the power path from the diff to the wheel).
Can you put on blocks? If one side is broken it should not turn with any torque (meaning it might turn in gear with the diff lock, simply from drag, but shouldn't have any torque). Come to think of it, it might be obvious if the engine were off and the unit is in gear, diff locked (tires off the ground). One wheel will likely turn, and the other will be locked. The one that turns has "issues".
   / 2006 TN60A 2wd model #3
You have at least one and possibly two broken differential hallf-shafts. If it will move with the difflock applied but not with it released, one is broken. If it won't move at all, both are.
