Uncle Hulka
I have a question about my 2555 HST. I don't know if this is normal, but I just discovered that I am unable to get the engine RPMs above 2,400. I know that is the speed for PTO operation, but this is without having the PTO engaged. Just sitting.
Last Saturday I mounted a 3-point hydraulic reservoir/pump (30 gal if memory serves) to power my FEL-mount Erskine snow blower. I believe this unit requires approx. 45-50 hp. I did a test run and at first (with cold hydro oil), I couldn't get the engine rpm above 1,800. The tractor only has 14 hours on the meter and this was the first time the engine had been put under any real load. I let it run awhile (5 minutes). With the oil good and warm, I could now reach about 2,150-2,200 rpm.
I know the PTO on a 3555 HST is rated at 42.5 hp, but shouldn't I be able to reach at rated pto speed with the blower doing nothing but, well, blowing?
The 2555 HST has a "Load Sensing" button. I have never used this feature. From what I understand, 'load sensing' is tied to the HST, to slow travel speed under extreme load. Does load sense have any impact on PTO power, even if the load sensing button is not on?
Bottom line, does anyone have any idea why I am unable to attain a higher engine rpm than 2,400 under no load?
Thanks for any help!
Uncle Hulka
Uncle Hulka
