justwannafarm
Looking for some advice here. I have a 5325 w/ Frontier SB1174 snowblower. Yesterday I engaged the PTO after disengaging and broke the shear bolt in the pto shaft where it meets the implement. I replaced it with a zinc one since the grade 2 I had were too short. Guessing the zinc was a grade 5? Today I engaged it once at idle, then brought up to 540 and it was fine for about 5 minutes, disengaged and went to re-engage and snapped the bolt again. both times I was at idle so I don't understand why I keep breaking bolts. The only difference now versus earlier in the season when I used it is that it's extremely cold out so everything is moving much slower (even spinning the auger by hand is harder but it's not binding up on anything)
Do I use grade 2 bolts or go with something higher? I've heard guys using grade 8 but that worries me. I don't want to cause any damage to the shaft or gearbox and would rather keep replacing cheap bolts and keep the blower running the entire time rather than engaging and disengaging.
