desross
My little 753 has been going very well right up until today when hydro oil started coming at the back right, I traced the problem to a connection between a hose and a steel pipe. Which is in fact the bucket crown action hoses, from where it leaves the arm into the rear frame it appears to go into a short hose running down into a steel pipe, both of which cant be got at due to plate steel on both sides.
Have you ever had to take these out ? I assume you have to undo steel pipes at valve bank and draw hoses and pipes out towards the bottom, even this looks like a mission just to get any movement out of the steel pipes as they do 2 x 90 degrees turns. Or do you know of any tricks or helpful hits on how to remove.
cheers
des
cheers
des
