luvbug
Has anyone had a problem with the fuel tank shifting foward to the point that you can not close the hood without removing the fuel cap? I have not been able to see how you remove the dash to gain access to see if the mounting bolts are loose. If I push on the tank it does not move rearward or side to side. The hood does not apear to have moved either. Any sugestions or ideas? I'm perplexed about this one. Other than this, I have had no other problems with this tractor. I have aproximately 185 hours on it.
