First off.. thanks for reading this and taking your time to help out!
I've got a 2003? 7610 with about 400 hours on it and never a problem with the drive (HST) mechanism.
Yesterday I was out clearing the drive with the front end loader when suddenly there was no power to the wheels. Everything else seems to be normal! Power steering normal. PTO normal. Bucket controls and power.. normal.
I've tried shifting from 2 to 4WD. Played with the clutch. The HST pedal feels normal and when engaging forward or reverse I hear what sounds familiar... but no go! Again.. this happened while operating and under some load with the bucket scraping the ground.
I've found no fluid leaks. I've not done an exhaustive search yet for anything broken but what I have seen looks normal.
Yes it has been freezing cold. I was happy when the tractor I keep only under a cover started up when it was 11 degrees after resting for a month. I had been running it for about an hour prior to this breakdown.
Questions and comments welcome. I don't mind having someone work on it if that's what it takes but if it something I can sort out and diagnose and/or fix I'd like to do it that way.
Thanks,
Richard
Franktown, Virginia
Thanks,
Richard
Franktown, Virginia
