Auger instruction
   / Auger instruction #1
Hoka Hey
I just used my auger for the first time yesterday. I've had it laying around now for a couple years. Everybody tells me that they won't work in our area because the ground is so hard. I was surprised how well it poked a quick 9" hole 3 feet deep! But, I was having a hard time getting it to drill a plumb hole. Am I setting something up wrong or is it just the nature of the beast?
   / Auger instruction #2
Actually thats normal, but can be corrected. I'll bet that all of your holes pointed towards the tractor didn't they. This is because of geometry, the top of the digger will get further away from the tractor as it lowers, the bottom cant swing any more because it is in the ground. This causes your holes to pint towards the tractor, or lean away from the tractor at the top of the hole, whichever way you want to look at it. To correct this you need to move the tractor forward as the hole gets deeper, how much is something you'll learn.
Good luck,
DuaneW.
(14) WOOD PALLETS (A60432)
(14) WOOD PALLETS...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
Champion Vibratory Roller (A60462)
Champion Vibratory...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
