Building Roads
   / Building Roads #1
W5FL
Veteran Member
Central Texas
TYM T-1104/TX10 Loader Kubota M6800SD/LA1002 Loader Kubota RTV900
Since Texas finally got some rain - unfortunately all at once, most of my driveway is in the ditches or the highway. It is now time for rebuilding. I sold my old box blade and am waiting to get another one. The county road behind my house was simply leveled, then very small rock/gravel put on it. I guess they rolled it and I guess you can rent a roller. Are rollers expensive to rent or buy? Then they sprayed it with some kind of black stuff that looks like a paved road except that it is very thin and probably just a binder for the gravel. Haven't found anyone who is set up to do this for residential driveways. Anyone have any ideas on how to build a gravel road and put some kind of sealer on it so it will stand up to the weather.
I guess if I can't figure that out I will eventually just get the Roadmaster grader attachment and keep it up after each rain.
The other thing that must be done is get all the ditches dug out so the water doesn't get on the road. I was hoping to angle a box blade to dig them out because I don't have a heavy rear blade.
I have also never done a really good job of crowning the road so that water does not run down the road. How do you crown an existing road without adding a lot more road base? Guess that is a dumb question, if I don't add more road base where will the gravel in the ditch come from next time. /w3tcompact/icons/laugh.gif
   / Building Roads #2
Wen, my drive is about a 1/2 mile long, and I had trouble for years untill I got a crown on it. Just got fed up and bought some reground asphalt rather than road gravle.This is not as dusty and seam to pack good. I don't know that else is in your ditch but you can use your loader to scoop up whats left of your road if the ditch isn't to deep and your road is wide enough!!I use a landscape rake to crown up the road , but you have to have some gravle to bring back to the center. Glad here you got some rain./w3tcompact/icons/smile.gif
Rich
   / Building Roads #3
Regular gravel here in Northern Ontario is a mix of sand and small rock. It's different than the small rock stuff that I remember being dumped on section roads. You know, the stuff that never seems to pack, and it feels like your truck is wind surfing unless you stay in the ruts. I think that's called pea gravel here.
Most people's drives here are regular gravel. It packs reasonably well, and after a few rains, there's a layer of packed rock on the surface. I believe that any road surface has to have a bed before in order to be very durable. Asphalt on dirt doesn't last long. I think of the sand/gravel mix around here as sort of self-bedding. Put down enough of it, and it's pretty durable once it's settled with sand beneath and rock on top. Of course, it's not going to survive going down the side of a wash in canyon country, but what will?
I'm going to do some work on my drive when I get the tractor back from our camp. I plan to get a load of gravel and improve the crown with a box scraper. I'll also dig the side drainage ditches deeper and put in some crushed rock to slow erosion in the ditches. I'll try to dig the ditches with the scraper, but I may not be able get enough tilt with the lower link leveler dig them out much more. Anyway, I'll do the crown first since it will give me a better angle for the ditches and then hope I can get enough tilt on the scraper. A good rear blade with tilts and swings would work better, but I can't justify having both.
I've got a hydraulic top link which is real handy with the scraper. I think there are hydraulic set up for lower links as well that perhaps could give greater tilt. I think Mark mentioned them.
There is a local company called 'The Gravel Doctor.' They advertise 'revolutionary process for restoring gravel drives.' I don't know what they do, but it seems like there is something other than just adding more gravel.
   / Building Roads #4
wen,
I have 450' driveway and 1/3 of the driveway has about 30 degree pitch,and once a year the water digs out the the ditches and where the driveway is level there sets the gravel./w3tcompact/icons/frown.gif
Since I purchase RI York I use the grader blade and clean the ditches.
I 45 degree the blade so the gravel once again be in the center of the road,than I use the rake to make my pitch.
From the edge of the ditch to the center I try and end up with a 4" pitch.
About evey 2 years or so I have a load of what is call hard pack bought in.
Hard pack is fine crush ledge and once in place it binds well,but the cost is /w3tcompact/icons/shocked.gif
I have notice more and more steep driveways are starting to use recycle asphalt mix with gravel, I just wonder how good that it is.
I've yet to read where you mention about asking a dumb question !!
Have a pleasant day. /w3tcompact/icons/smile.gif
Thomas..NH
   / Building Roads #5
TomG, if you get a chance sometime, check out the "Gravel Doctor" folks and let us know what their bag is. I'm very interested!
Yes, as you mentioned, I've got hydraulic cylinders on my side links. I've got one on both sides, because I'm a nut, but for most folks one side is probably just as good, and half as expensive.
Mark
   / Building Roads #6
Wen
Since being in the excavation business for many years (until 99...retired or got tired) I can give you some less expensive methods to crown the ole drive. First of all, If your drive is wide enough to permit, cutt as much of your base material off the road surface as possiable (either blade it to one side or bucket move it) Then If you happen to have any clay soil on your property start digging. Haul as much clay to your drive as you have available or until you have about 8" (or greater) depth x width of your drive. Then use your road master with a pitch set at about (d.s.-ditch side,c.d.- center of drive) 2"-d.s., 6"-c.d. maintain this setting and drag your drive from one end to the other on both sides. You will see your crown start forming as you work the clay. use the trial and error method on your blade settings by the way. When you have a good crown built then, use your front loader with as much down pressure applied as possiable and, still be able to steer the tractor. set your bucket in the level postion and back drag the clay first one side of the drive then the other (avoid centering the drive with your machine) work only the contour's. a front loader bucket will apply a great amount of packing pressure ( soil density tests have been passed useing only a loader bucket for packing). When you have a good,well packed crown built. again use your loader and move the old material back to the drive surface. I suggest spread dumping the material with your bucket then use your box blade or loader to dress it. or you may choose to have new material hauled in for the top surface. In our area I suggest nothing less than a Grade #2 base. You can contact Vulcan Materials in Weaherford for current pricing and delivery. The last load's I hauled from there over a year ago, my cost on the material was $3.75 a ton. I delivered it locally for $10.40 per ton.
I hope this helps with your problem.
Cowboy
BigBoyz Toyz
   / Building Roads #7
Both the clay and the bucket packing sound like good ideas. I packed my gravel by smoothing it with the back of a box scraper's rear cutter and then drove on it a lot. The bucket idea sounds a lot better.
I'll just mention that some care in using clay is needed. Some waterfront cottagers behind us have a private road. Some of them got together and decided that cut above the road washed down on the road too much. According to the story, they brought in a bunch of clay to stabilize the cut. I don't know how it was applied, but I've seen exposed clay layers with topsoil burdens. Now, the exposed clay washes across the road and into several of the yards. I understand a few people aren't real happy.
   / Building Roads #8
The key to maintaining any road or upgrading is the base and that will depend on what you have available in your area. My last house had a very long drive and it became a pain to keep graded I even build a custom rig to use on it sort of like the grademaster. It worked great but still was a pain.
I ended up buying what they call in this area is millings, its ground up asphalt and it ran me $100.00 a load for the material. I put it down 4-6 inches thick and once packed it was like a paved drive!!! About two years later I added some more where it was starting to break up in some areas and pothole up. Now at the new house I'm back to a gravel drive and a box blade, but in time I'll do the same get a few truck loads of ashpalt millings alot less hassle no dust and packs like a real paved drive.
Gordon
   / Building Roads #9
Wen where I'm from we call that tar and chip. The county uses it a lot on their roads because its cheaper than blacktop. I don't know anyone that has their drive done with it, because in the summer the tar will bubble up. This is picked up by the tires and slung on the sides of your vehicle. The county usually spreads a thin layer of dense grade over the road to prevent this.
   / Building Roads
Cowboy,
Thanks for the information. Is your company still in operation.
My son is trying to find out what it will cost to get a road built. He was looking at some property that would require him to build about 1000 ft of road to get to it. I walked over it yesterday right after the big rain in Weatherford. It is in Peaster. The tank was running about 5 inches deep over the spillway which crossed the dirt road and we walked in about 2 inches of water over a lot of the road. Kinda afraid he is getting into a pretty good sized project.
2001 BIG TEX GOOSENECK (A55745)
2001 BIG TEX...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
