Msudairyfarmer
- Joined
- Jun 5, 2018
- Messages
- 2
- Tractor
- Case IH
Hi everyone,
I have a 55a 2wd mech shift I've owned for awhile now. Awhile back it kept shutting off in the field and fixed a relay on it. Later last fall I had issues with a spade fitting on the solenoid that would not allow it to crank and that was fixed. Now I have encountered the same issue where I can not get it to crank. When I turn the key I can hear the relays clicking as usually and all lights work. I checked the seat safety switch, the range lever switch, and the pto safety switch and all tested fine. I was wondering if anyone had suggestions. I have not found any loose or bad connections. I could really use some help on this and it would be greatly appreciated!
