Farmall fast hitch
   / Farmall fast hitch #1
Don62
Hope Hull,Ala.
'53 Farmall Super "C", '53 Ford NAA , '53 Ford 9N , '47 John Deere "B"
I have Farmall Super "C" with a two point fast hitch. Are there any plans available to convert my disk from a 3 point to a 2 point
   / Farmall fast hitch #2
Suggest you get the conversion from FH to 3pt, ie. the arms and the retro toplink change over from the belt pulley cover to the toplink connector...do it once and you can use all your 3pt attachments, versus, just what you convert to 2pt...BobG in VA
   / Farmall fast hitch #3
agri supply has the points that can be bolted or welded onto your disc to make it a fast hitch disc
   / Farmall fast hitch #4
Nat, When you say agri supply, are you referring to Tractor Supply Company?? I saw the fast hitch prong on ebay for about $70. , which I thought was high. I was looking to buy a 1 point plow (with fast hitch) for the Farmal Cub , but missed one at $150. last week..
2015 MACK CXU613 TANDEM AXLE SLEEPER TRUCK (A59575)
2015 MACK CXU613...
Toro 880 Procore (A55758)
Toro 880 Procore...
FUEL PUMP W/NOZZLE (A58216)
FUEL PUMP W/NOZZLE...
2827 (A58376)
2827 (A58376)
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2008 Hooper 20ft Gooseneck Flatbed Trailer (A57453)
2008 Hooper 20ft...
