gailcahill
Ford 1620 HST tractor. Loosing forward motion when going up a hill, engine then gets bogged down. I would appreciate any advice how to fix or diagnose
Not a "new to me" tractor...I was driving on the road in High 2wd and it struggled to the point of stalling to make it to the top. I put it med and it struggled but made it. The symptom of not going forward on a steep hill is new to me just yesterday. When I got home I tried a test on a fairly steep but not very long (10ft) embankment. I was in high 2wd and the tractor would not forward once under the load of the hill. I put it in med and it went up. I have noticed in the past two years that I loose some power when driving in high gear(2wd) on the road. I have not had the problem of the engine getting completely bogged down though.Is this a new symptom or a new to you tractor? How steep of a hill and did you have it in low range?
Thank youThat is what I was thinking. This is a common issue with HST. Most people have a tendency to push harder on the pedal when climbing a hill like they would driving a car. You might find it could climb the hill if you have the hand throttle all the way up and ease off of the HST pedal as the engine starts to bog down. But choosing the correct range for the hill still is the best answer. I do not believe there is an issue with your tractor.
That is exactly the first symptoms of a clogged fuel filter. Change the fuel filter and see if that helps.Not a "new to me" tractor...I was driving on the road in High 2wd and it struggled to the point of stalling to make it to the top. I put it med and it struggled but made it. The symptom of not going forward on a steep hill is new to me just yesterday. When I got home I tried a test on a fairly steep but not very long (10ft) embankment. I was in high 2wd and the tractor would not forward once under the load of the hill. I put it in med and it went up. I have noticed in the past two years that I loose some power when driving in high gear(2wd) on the road. I have not had the problem of the engine getting completely bogged down though.
