Hi,
I have a 1995 Ford 2120 with electronic shuttle shift transmission and 4 wheel drive. The tractor was serviced this summer because the PTO was locked up and damaged the PTO clutch and other parts. The tractor ran fine for 3 months. Recently the transmission would stay in forward when shifted into reverse. Switching the gear to neutral and then reverse allowed the tractor to go into reverse. The problem has become permanent where the tractor stalls when it is put into reverse.
I tested the electronic circuits and it appears that the power (~13 volts) is being delivered to the forward solenoid only when the selector is in forward. With the selector in neutral the tractor is in neutral no power to either solenoid. When the shifter is in reverse power is delivered only to the reverse solenoid.
Has anyone had a similar issue and advice? I am currently thinking the hydraulic clutch pack section may be damaged.
