/ Ford F2000 lift arms not working. Hydraulic fluid was low and I also drained it. But Still isn't working. What could be my problem besides it being pu
Hydraulics not working to raise the lifting arms. What could be the problem besides low fluid or pump
Ford 7710, Ford 550, Ford 1910, Ford 4430, KD Forklift, Ford LGT17H, New Holland L255 Skidsteer
Is this a 3 cylinder or 4 cylinder 2000?
Were things working before you drained the fluid? Did you check the strainer or filter for crud build up which would block fluid flow to the pump? I do hope you refilled the fluid to the proper level.
