BertZegers
- Joined
- Jan 2, 2012
- Messages
- 261
- Location
- South-West Ontario
- Tractor
- Kubota L2900, Zetor 8011, Kubota KX41Excavator, John Deere 4400 Combine, Case 1816C skidsteer
Can you explain how this can happen?a stuck open injector
I think it is very unlikely.
To have a stuck open injector causing diesel to leak into the crank case is very unlikely. It would need gravity feed of diesel, pump piston for that cylinder in the "down" position, a stuck open delivery valve, and a stuck open injector (when parked). And when started an engine smoking and running badly.
