ruready1
Hi all,
We're REALLY needing ideas on how to safely widen our L3400. When we picked it up, the dealer stated it would do the 1000-1200# round bales with no issues. We've found out the hard way that this is only partially correct. Using a bale spear in place of the bucket (LA463), it will pick up the bales without too much issue. When we go to move the bales, that's when it gets interesting!!!! Our land is mostly ridgetop and there aren't many flat/level spots bigger than the tractor!!! We'll be doing well and the next thing you know, the front tucks under and the tractor tries to go over. I thought I was just paranoid but when I put a grade meter on it, it says I should be scared. We have too much in this new tractor to trade it in or sell it, so can anyone please suggest how to make it more stable on uneven ground??? I know you're not supposed to reverse the fronts. A former mechanic suggested moving the centers to the outside set of loops and switching sides for the rear but I'm not sure that'll even be enough. I'd hate to find out it won't give us enough stability and have to switch back since they're loaded w/beet juice (HEAVY). The rears are currently set up to be 60" outer edge to outer edge to match the loader bucket. Can duals be added to a L3400????
Any suggestions would be appreciated. We've even considered getting a larger 50+ hp utility tractor like an old Ford 5000 just to do bale feeding but considering we only feed once a week, that's a lot of $$$ for something that'll sit more often than not!
Thanks all,
Mike
Thanks all,
Mike
