Rak542
I have kubota L5740. About a year ago I filled my tractor up with diesel. At the time it only had about an 1/8 of a tank. After the fill up I drove the tractor for about 15 minutes. Then it started stuttering and white smoke came out of the exhaust and then it died. I got out to check the fuel filter/water separator bowl end it was full of water. I drain the water out of the filter and out of the tank. I put new diesel in and after about one hour of messing with it I finally got the tractor to start. Fast forward to last week, I was using the tractor to brush hog. And I noticed every time I accelerated the throttle it sounded almost like I had an exhaust leak. So I stopped brush hogging and started checking everything out. When it’s at a steady RPM it doesn’t sound bad. But when you accelerate the throttle it still sounds like an exhaust leak. It also makes the same exhaust leak noise when the tractor is under load like when I’m brush Hogging. I took it to the Kabota dealer and they told me that I had a bad injector and the injector pump was bad. They said this was because of contaminated fuel. More or less water in the fuel. My question is does this make sense it has been almost a year since I had the water in my fuel issue. Any advice would be greatly appreciated. Thank you
