Lawn Preparation
   / Lawn Preparation #1
MacMurphy
I have 10 acres of lawn that I am currently preparing, the soil is excellent however there are many smaller stones thoughout it that I would like to filter out.
What is the best way to remove these stones and prepare a nice bed for the lawn ?
Murph
   / Lawn Preparation #2
Not easy, but perhaps a landscape rake will help - maybe you can rent one. This is what I did for 2 acres of new lawn, but it still involved a bit of walking and chucking rocks.... /forums/images/graemlins/confused.gif
   / Lawn Preparation #3
You need to rent a harley or similar power rake.
   / Lawn Preparation
Is a landscape rake a 3pl implement or is it a standalone powered tool ?
Murph
   / Lawn Preparation #5
Murph,
</font><font color="blue" class="small">( Is a landscape rake a 3pl implement or is it a standalone powered tool ? )</font>
Imagine a rear blade with tines instead of the blade. Here's a link:
Landscape rake
   / Lawn Preparation #6
I used a skid steer with a "rock hound". It levels, loosens the seed bed and collects the rocks in the loader bucket. I started with fairly rough (dozer leveled) topsoil, and it took only one pass to prep the seed bed.
John
   / Lawn Preparation #7
We used a Harley Rake to clean rocks on the fairways of a golf course last August. We ended up still walking around with five gallon buckets and picking them up by hand. I have tried landscape rakes and harley rakes and box scrapers. There is just not an easy way. The great thing is it gives you a lot of seat time.
   / Lawn Preparation #8
Please define what you are referring to as "rocks". anything under the size of a small potato I consider not worth trying to remove. Sure, if you spend a lot of time, you might be able to get them all out this season, but next season there will be a new crop that you will be dealing with. As the ground freeze and thaws, the rocks are being drawn to the surface. I have learned that unless you are going to remove the top 12" of top soil, screen it, and put it back, there will always be rocks in the soil, just depends on how far down you want to look for them. Depending on how deep your topsoil is, will make a big difference. If it is at least 12" deep, you can till the entire surface and then use a Harley rake to get the rocks out. If you only have 3" of top soil, then you will need to be careful how you prepare it, so you don't mix the top soil with the material underneath. Just remember that there will be many rocks to deal with. If it were my lawn, I would just prepare the top 3" of soil and not worry about anything under that level. Fertilize and seed. Once the lawn is growing and you have a full healthy turf, the rocks under the surface will be of no consequence. In the spring, it will be necessary to walk the lawn looking for any rocks that will have sprouted over winter. I paved my driveway 10 years ago and put down a 2' base of sifted gravel. The largest stone in the material was about the size of a golf ball. After the last few winters where we had below freezing temperatures for weeks on end, in the spring I found that a large mound was forming under the pavement. When the contractor came to look at it, he knew exactly what it was. A large boulder that came up from deep below. After they cut out a 5' square and dug down, they found a very large boulder just as he had predicted. I already can see some more of them pushing there way to the surface this winter. I dread the thought of what will surface in the lawn this spring also, but that it the nature of rocks. It is hard to keep a good rock down. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif Grass is just another way of hiding them.... /forums/images/graemlins/crazy.gif
   / Lawn Preparation #9
I'd try to rent either a Preseeder or a Rock Hound. They actually work great together. One collects the rocks & the other picks up your windrows. If your soil's already loose & levelled I'd just go for the RockHound & a skid loader. You will be done in half a day! /forums/images/graemlins/cool.gif
Wait, 10 acres?!? Forget that. Go with the Preseeder & just use the RockHound for cleanup in the end. You'll be done in a week! /forums/images/graemlins/cool.gif
   / Lawn Preparation #10
Howdy,
You can hire a Cultivator or Rotary Hoe from your local hire shop for large areas and work up the ground to a depth of 100mm to 200mm adding organic matter on sandier soils as you go. This can then be smoothed out with a rake. The ideal soil ph for turf grass is in the range of 5.5-6.5. Soil ph kits are available from most garden centres and are inexpensive.
You can learn more about ground preparation from this site: Turf Supplies Sydney Preparation | Sir Walter Turf Sydney Preparation | Green Life Turf Specialist Quality Instant Lawn Growers Preparation.
Hope this helps! Cheers! :thumbsup:
2016 Chevrolet Silverado 2500 HD 4x4 Pickup Truck (A55973)
2016 Chevrolet...
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
2007 FORD F-150XL TRITON TRUCK (A51406)
2007 FORD F-150XL...
