dntfxr
Platinum Member
I have a '93 B7100 -awesome little machine- that spent most of its life in the weather.I recently rescued it, however one of the casualties is a leaking seal on the input shaft of the HST. I have scheduled to have the seal replaced at my dealer at the first available opening - which is 2-3 weeks from now. However, I really need to use the tractor next week. Are there any conditioners or thicker hydro fluids that are safe to use in my tranny that may slow the leak so I can get my job done?
If not, I already have the new replacement seal and o-ring that goes behind the charge pump case. I am seriously considering buying a large floor jack and/or engine hoist and splitting the tractor to do the repair myself. Does anyone know if the whole transmission would need to be removed, or just the three bolts holding the charge pump case to get to the seal once the tractor is split.
BTW its the seal right below the HST filter on the front of the transmission where the shaft from the motor goes to the HST.
