oil dripping out my exhaust pipe
   / oil dripping out my exhaust pipe #1
markfromsparks
1982 Ford 555
Hello everyone, I have a 1980 or close to that, Ford 555 loader backhoe with a 3 cylinder Perkins Diesel engine, it starts great even freezing weather, runs smooth, don稚 smoke, only when it starts and when you push on the petal.
When I start the tractor and let it idle to warm up I start seeing oil looking ( looks and fells like oil ) coming out of my exhaust stack seam above the manifold where the pipe slips over riser above the manifold? I知 not sure what this is ? It痴 not affecting the motor that I know. Is this stacking or slobbering? It has just started. I just bought the tractor and have been working on it for the past year due to lack of time and hydraulic pump problems so I haven稚 had a chance to put it to work. Has anyone had this problem before ? Thanks Mark
   / oil dripping out my exhaust pipe #2
I'd suspect mostly sloppy oily condensation.
I presume you have monitored your oil levels.
Also do U cap or have a flapper on the exhaust pipe? Might just be dirty water leaking out.
If oil consumption remains normal I'd just chalk it up to usual diesel slob.
   / oil dripping out my exhaust pipe #3
Most likely "diesel slobbers" or "wet stacking" due to the low exhaust temperatures from idling. Work the snot out of it and that will clear up.
I will let you guys know how everything works out
Thank you
   / oil dripping out my exhaust pipe #5
Plus one and you need to 'work' on your spelling too.:D
   / oil dripping out my exhaust pipe #6
