Results 1 to 7 of 7
04-06-2012, 08:46 PM #1Bronze Member
- Join Date
- Apr 2009
- Posts
- 96
- Location
- Jefferson, ME
- Tractor
- Pasquali 988
520 Wheel Horse not charging
Hello my neighbors 12 yr old son bought a 520 Wheel horse to mow lawns and make money but nfortunatly it is not charging the battery. I checked and the voltage at the battery is not increasing when the engine is running. Im thinking it is either the voltage regulator or the coils.
Does anyone know where the voltage regulator is?
Any idea what typically breaks on this model to cause the battery to not be charged?
Thanks
~ Phil
05-24-2012, 10:31 AM #2New Member
- Join Date
- May 2012
- Posts
- 3
- Location
- Oklahoma City, OK
- Tractor
- Currently have a Honda H4518 & H4514, a John Deere LX178, & Craftsman DYT4000.
Re: 520 Wheel Horse not charging
Hello,
I have a manual that may help you out if you still havent solved this problem.
Just email me if you would like it... It covers all 1985-2001 wheel Horse Tractors.
03-04-2013, 11:42 AM #3New Member
- Join Date
- Mar 2013
- Posts
- 1
- Location
- TROUTMAN, NC
- Tractor
- Toro Wheel horse 520HC
I am having the same problem... Can you also e-mail me the manual? Thanks Derek
03-04-2013, 12:20 PM #4
What engine is in that? I have a 25Hp Kohler engine that there was a fuse in. I replaced that and it blew out again. Underneath the flywheel was the alternator charging system. One of the magnets had come off and turned into shrapnel under the flywheel I had to replace the coil and flywheel.
1st Peter 1:6-9
03-04-2013, 05:01 PM #5New Member
- Join Date
- Dec 2012
- Posts
- 5
- Location
- Minnesota
- Tractor
- Case
ambrod
i have sent you a p.m. about your 520 engine problem.
thank you. boomer ( the used onan engine parts guy )
03-05-2013, 11:05 AM #6Member
- Join Date
- Apr 2009
- Posts
- 31
- Location
- wayland,ny
- Tractor
- jd 4510
mine is doing the same thing, sometimes it charges and then it will stop or go to like 10 volts.i have changed the part behind the flywheel and it didn't help.
03-20-2013, 10:12 AM #7New Member
- Join Date
- May 2012
- Posts
- 3
- Location
- Oklahoma City, OK
- Tractor
I have an electrical manual that covers all Toro WheelHorse models. 1985-2001...
"Toro Wheel Horse Demystification Electical wiring diagrams for all Wheel Horse Tractors.pdf"
For whomever wants it please PM me with your email so I can send it to you. The pdf is 30.5mb large.Hours don't matter, It's maintance that counts!!!
Similar Threads
Wheel Horse 318h
By Mal AC in forum Toro / Wheel HorseReplies: 9Last Post: 04-14-2012, 12:49 PM -
1988 wheel horse 520 hc power lose
By zlock24 in forum Toro / Wheel HorseReplies: 3Last Post: 01-21-2012, 07:14 PM -
Price Check Wheel Horse commando7 3speed
By coolperson9693 in forum All Other BrandsReplies: 1Last Post: 07-11-2011, 07:15 PM -
1937 Wheel Horse.....
By DJ54 in forum Toro / Wheel HorseReplies: 6Last Post: 05-10-2010, 08:53 PM -
Horse trailer ?
By ChrsDrn in forum Trailers & TransportationReplies: 27Last Post: 01-15-2010, 08:53 PM
