Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Aug 2010
    Posts
    6
    Southeast NY
    2004 520XI
    Default 520 xi overheating
    Has anyone experienced a situation with a 20 HP Kohler air cooled on a 520 XI where the guage says it is getting to hot but I can't find any obstruction around the engine or oil cooler?
    I have blown everything out with high pressure air but the way the engine is installled the back of the engine is inaccessible.
    Since Kohler offers a kit for access panels to clean out the rear of the fins I suspect this may have been a design flaw although the back of engine where these panels would go is still inaccessible since it is up against a firewall on the 520XI and installing them and using them would involve hours or disassembly.
    The machine runs smooth so I don't think it is running lean... is there a way to check it out before I throw down $70 on a new temperature sensor??
    Love the machine and it only has 65 hours... it is a 2004 that I got from a dealer after they were discontinued.
    Any input appreciated!
    WHW
    WHW
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    New Member
    Join Date
    Nov 2004
    Posts
    19
    Connecticut
    Wheel Horse 522xi
    Default Re: 520 xi overheating
    Hi WHW,
    I have the Kohler service manual for your engine (I have a 522xi), and for overheating it list the following possibilities:
    Air intake/grass screen clogged, cooling fins, or cooling shrouds clogged
    Excessive engine load
    Low crankcase oil
    High crankcase oil
    Faulty carburetor
    Lean fuel mixture
    SMART-SPARK, malfunction (applicable models)
    I have not had an overheating problem with my tractor, so I can't point you to anything in particular.
    How long does it take before it shows "hot"?
    What are you doing when it reads "hot"? Mowing at full rpm?
    Did anything change recently, did you change the oil?
    Rick
  4. #3
    Elite Member
    Join Date
    Sep 2008
    Posts
    2,870
    NE USA
    JD LA115, WH 244, WH 525 hydro-pops,Original Troy Built Horse 8 HP
    Leave the air filter assembly in place and use a leaf blower to clear out the dust in the area
    around the air cleaner everytime you mow and the entire engine
    compartment as this will
    solve the issue for you.
    Are you using Sea Foam for the fuel? We had our 525 muffler plug up from carbon
    and we also had a bad set of coils.
Similar Threads
  1. 520-H problems
    By ringo6921 in forum Toro / Wheel Horse
    Last Post: 01-21-2012, 09:57 AM
  2. makita 520?
    By Builder in forum Chainsaws
    Last Post: 04-28-2011, 12:13 PM
  3. Longtrac 520/530
    By danny11b in forum Farmtrac
    Last Post: 12-28-2010, 09:43 AM
  4. JD 520 hydrilics
    By DonWorrell in forum John Deere Owning/Operating
    Last Post: 06-29-2010, 09:53 AM
  5. R 520 loader
    By Tags in forum Kubota Owning/Operating
    Last Post: 02-11-2002, 05:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
