Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    Member casey lb1914's Avatar
    Join Date
    Oct 2006
    Posts
    28
    Upstate New York
    Kioti LB1914
    Default License a homemade trailer
    Has anyone from NYS experienced getting a homemade trailer over a 1000# licensed ? I stripped a camper trailer off the frame and put on a deck, it is a 6x16 tandem axle w/elec. brakes now I need to get it on the road. I know the state needs to inspect it also the DOT. Iam close to Rochester. I have called DMV but as always, thats like pulling teeth to get an answer, where do I go for the DOT inspection. I will post my pics when I get a chance.
    Attached Images Attached Images
  2. #2
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Default Re: License a homemade trailer
    Nice job. I am not in NY but here in Indiana we go to the BMV and get a form along with a VIN#. You then place that VIN# on the trailer per the instructions and fill out the from. You then call your local Police and they send a man out who checks the trailer over and signs the form. You then you go back to the BMV and you are issued a title and you get plates. You are then set. Once again nice trailer.
    Chris
  3. #3
    Elite Member ToadHill's Avatar
    Join Date
    Oct 2005
    Posts
    2,711
    Catt county New York
    Kioti DK35, Ford 8N, Oliver Cletrac
    First you have to go to a state approved weigh station and have it weighed. You'll need a certified form from them. Then you need to determine it's carry capacity,(should be printed on the axles).
    Your local DOT office should have a form you can fill out. They will assign you a ID# which you have to stamp into the trailer frame.
    I did it several years ago and it's not too hard.
    Get the form first and take it with you to the weigh station, if you are stopped by the police you can show them the form and you should be "ok".
    I can't control my day but I can control my attitude.
  4. #4
    Join Date
    Feb 2006
    Posts
    104
    The Pas, Manitoba, Canada
    Good timing!
    I was looking up info yesterday and came across a NYS downloadable pdf form that you would use to have your homemade trailer registered.
    While I cannot recall which site it was, you should be able to find it with a search.
    I will try searching for it, but you will probably beat me to it if you are on anything faster than dial-up (which is what I have).
    Hopefully I can post a link shortly.
    PS ... that is one nice trailer!
    Chris
  5. #5
    Join Date
    Feb 2006
    Posts
    104
    http://www.nysdmv.com/forms/mv272.pdf
    Try this. I just found it, but did not download it to check as that would add a whole lot of time and hopefully you can download it and check quicker than I can.
    HTH
    Chris
  6. #6
    Platinum Member Mighty Dodge's Avatar
    Join Date
    Jan 2007
    Posts
    516
    The Hereford Zone, MD
    JD 4200
    Nice trailer. How much weight do you plan on hauling? The reason I ask is because without the camper on it how rigid is the frame? I don't know if that may cause you any problems with the DMV.
    Good luck
    M.D.
    2001 JD 4200, 420 loader, HF Quick Hitch, bucket boom, back blade, boom pole, forks, carry-all, moldboard plow, middle buster, receiver hitch, post hole digger.
    My Pics
    http://www.tractorbynet.com/photos/s...0/ppuser/33421
  7. #7
    Super Member kenmac's Avatar
    Join Date
    Feb 2005
    Posts
    7,595
    The Heart of Dixie
    Yanmar3110D, Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
    Quote Originally Posted by Diamondpilot
    Chris
    Same for me in alabama( I had to make up my own VIN#) Except we go to the DMV ( dept. of motor vehicles)instead of b?mv
  8. #8
    Elite Member
    Join Date
    Oct 2000
    Posts
    3,056
    Windham County, Conn
    Ford 2120 , New Holland TN75D, Hitachi UH083LC Excavator
    I checked out that form. It is only for trailers than weigh less than 999 lbs empty. There is a different, slightly harder and more expensive procedure for trailers weighing over 1000 lbs.
    See NYS DMV - How to Register a Trailer that is Homemade or Custom-built
    Andy
  9. #9
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Quote Originally Posted by kenmac
    Here in Indiana we have the BMV. Bureau of Motor Vehicles. This is all thanks to our make things easier Government.
    Chris
  10. #10
    Join Date
    Oct 2006
    Posts
    28
    Upstate New York
    Kioti LB1914
    Thanks for the responses, the NYS link was a big help, it appears that the state DOT issues me a VIN# after they inspect it. Heres some pics of the project, I stripped the frame and added supports. The most I had on it was my Kioti tractor with FEL and box blade. I would quess all of 3000# took it down the road with no problems. Now to get it legal.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
