HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Trailers & Transportation
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 05-04-2008, 06:47 AM   #31 (permalink)
Super Member
Egon's Avatar
Default Re: Weight Distributing Hitch Questions and More
Moss; you are going to have to make up your own door sticker that has whatever tow weight you desire on it.
__________________
Egon
50 years behind the times
Livin in a
Worn out skin bag filled with rattlin bones
Egon is offline   Reply With Quote
Old 05-04-2008, 02:19 PM   #32 (permalink)
Super Star Member
MossRoad's Avatar
Quote:
Maybe if I forge it convincingly enough, I can claim it was there when I bought it if I get in trouble.
Yeah, it says right there on the door that it can tow 20,000!
__________________
MossRoad
MossRoad is offline   Reply With Quote
Old 05-04-2008, 05:35 PM   #33 (permalink)
Lasgambler's Avatar
I have had and towed with several diff. types of WD hitches. Hands down, my fav. is the Reese trunion style with dual-cam sway control. You have complete control of a 30 ft trailer at 75mph with the above set-up. I know this from experience that I hope I never have to "witness again."
__________________
YANMAR FX42d, Koyker 155 FEL, ROPS w/Canapy, Top & Tilt Gearmore BS w/ Hydraulic Scarfiers. Loaded R4 Industrial Tires, Princess Auto BH w/ Subframe. Boom pole. Pallet Forks.
Lasgambler is offline   Reply With Quote
Old 05-07-2008, 05:33 PM   #34 (permalink)
Okay - so I think I'm going to buy a WD hitch.
Here is the one I'm looking at - I says good for 12,000lbs and 800 - 1,200 tounge weight which is a little overkill but they are all the same price and the next size down is 8,000lbs which is fine but it is for a 500 - 800lb toungue weight and that seems a little light maybe.
Southwest Wheel
How much difference is there on the brake controllers? Is the fancy $160 controllers that much better than the $90 controllers?
Tekonsha P3
I guess you need to call to get the TBN discount? Maybe that will make up for the fact that they will charge me sales tax since they are in Texas.
I push the limits of my Chevy Z71 pickup and my 7,000lb trailer about 4 times a year hauling it 100 miles each way and I probably should invest in the WD hitch.
__________________
1996 Kubota L4200 GST, LA680 FEL, + several attachments
www.padens.com
npaden is offline   Reply With Quote
Old 05-07-2008, 05:50 PM   #35 (permalink)
Quote:
Originally Posted by MrJimi
There were 2 links to them in my post above but that doesn't help answer my questions!
__________________
www.padens.com
Old 05-07-2008, 06:25 PM   #36 (permalink)
Epic Contributor
Bird's Avatar
The first one did not work, thats the only reason I posted a link
It didn't work for me, either, so I fixed it so it does work now. At least it now works for me, so I hope it works for everyone else, too.
__________________
Bird is offline   Reply With Quote
Old 05-07-2008, 06:44 PM   #37 (permalink)
I called them and they recommended the lighter hitch with the 8,000lb rating for me.
They said the discount was for online sales only and to enter TRACTORBYNET as the coupon code and it would give you a 5% discount.
__________________
www.padens.com
Old 05-07-2008, 09:28 PM   #38 (permalink)
did you buy the brake controller yet,i have a new in the box tekonsha prodigy,ill sell you for 75.00
hench861 is offline   Reply With Quote
Old 05-08-2008, 02:11 PM   #39 (permalink)
hench861,
I sent you an email through your TBN account. If you didn't get it you can send me a Private Message.
Thanks, Nathan
__________________
www.padens.com
Old 05-14-2008, 05:50 PM   #40 (permalink)
KAB
Gold Member
Moss,
I had a chance to stop by the dealer that has information back to 1990. I was thinking that you had a 94 so I am 1 year off. Although the numbers are the same as what my 90 Blazer was so they should be ok.
Please read the bottom notes on the attached sheet. The codes that are listed there should be in the glove box on the build tag.
To find which axle ratio that you have there will be either of the following codes:
GU6 = 3.42 axle ratio or
GT4 = 3.73 (I don't think that these have changed since 93)
While there also check for G80 which is the Eaton Automatic Locking Differential.
KAB is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
