#12 (permalink) | |
Quote:
injection pump 1798.00 + 6.1 hours lift pump 162.96 1.0 hour fuel filter housing (complete) 213.00 1.0 hour drop tank clean lines 150.00 to have tank boiled + 5.0 labor injection pump gasket 2.00 intake gaskets 35.00 15 gallons of diesel + stanadyne performance formula (20.00) added to fuel to get warranty on pump fuel injection nozzels are 80 - 120 depending on how much your parts guy likes you glow plugs are about 30.00 each pull the turbo and knock it all out at once, turbo remove heat shield, 4 15mm mounting bolts to manifold, 8mm band clamp bolt ( losen up exhaust at flange makes it easy to install) air outlet hose and braket. soak the manifold bolts the night before in heat riser penitrate to make removal easy. when you pull the fuel return lies off be very carefule with the clamps they are 3.00 each, put a dab of greese in the ends of the return lines and push them back on with the clamps in place or you will be hatin life on another note we just droped a brand new 6.5 in a 95 1 ton, her bill was 13,000 and some change have a nice day
__________________
Kubota b3030, LA 403, BH 75, Kubota ZD326, redneck thumb, grade blade, 07 GMC V-MAX, 08 GMC DEANLI, 18' Car huler, Stihl ms290, stihl combi system, stihl br550 blower, hh130 mig, victor torch, snap on hand tools and cornwell box ect................... |
#13 (permalink) | |
Quote:
Chris |
#14 (permalink) | |
Quote:
6.5's have a few quirks and really got a bad name because of all the guys who didnt know what they were doing when they worked on them. ive worked on them for 10 years and actually enjoy it. easy money ![]()
__________________
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
