#11 (permalink) |
It would cost more to get 5k axles, but you might want to check into it. It is very easy to overload a 7k trailer. JC
__________________
JD 3320 LX5, KK rake and off brand box and rear blade. Millonzi grapple. Deere X495 for grass cutting. 01 Ram 4x4 2500 CTD and 22' 12k trailer. Want a tiller and dump trailer. |
#13 (permalink) |
Gold Member
just paid $2200 for a 20' version, no dovetail, but it has a diamond plate floor instead of wood planks, a spare tire with rack, and adjustable hitch.
agreed, the trailer weight itself takes a pretty good bite out of the axle load bearing capacity, but i can't pull more with my truck anyway, so it is a good blend of form and function for my particular needs. adding heavier axles adds weight and might tempt you to try to haul more than your truck is rated for. i got mine from millertime manufacturing in nowata, OK. the only thing i would have changed is have them move the axles up about a foot forward under the frame. i have to load the tractor all the way to the rear to get a good weight balance and i would prefer to be able to pile more implements and other things (mulch, dirt, whatever) up front. they way the axles are now, it kind of limits me unless i counter weight the rear to get a balance. overall, though, a well built trailer. here's a pic or two. days are heating up around here, starting to long for those cold wintery temps! amp
__________________
PM me with your email address to receive my Monthly Lawn & Garden Calender of Reminders. Helpful tips in your email each month. Kubota BX24 (loader, hoe, 60" belly); Ford 800 tractor; Scott's/Deere 42" mower; 5' and 6' rear blade; 54" Howse tiller; 20' 7,000 lb carhauler trailer; 2 other trailers; 5' dethatcher; 10" single bottom moldboard plow; middle buster plow; 600 lb roller; 3pt auger; front tire chains; Stihl and Honda small engine equip. Growing with you season by season. |
#14 (permalink) |
Gold Member
Sounds way too cheap to me. A similar trailer 6 yr ago cost me 2,300.00. Adjusting for the price of steel would probably be closer to 3,000.00 now. I just sold mine. I don't recommend 7000GVW because of the limited hauling capacity. Just because a trailer is rated for more doesn't me you will tow it at that weight. But the extra beef will actually pull easier and will give you a margin of safety. My new one on order is 14K deckover BetterBuilt 20+4. I can't tow 14K but at least what I do put on it will look like its meant to be there. Oh yeh.... the price......6500.00 and some change.
#15 (permalink) | |
Quote:
What's the axle ratings?
__________________
Premier Lawn Care & Landscapes, L.L.C. 2006 Chevy 2500HD 4wd CC/SB Duramax LBZ/ Allison 1000 6 speed LT1 Blue Granite Mettalic 2008 SCAG Turf Tiger - 27hp/ 52" 2006 LESCO 36" Hydro walkbehind TORO personal pace 21" STIHL KM-110 Kombi-system STIHL FS-55 trimmer STIHL BR-600 blower REDMAX 7001 blower STIHL BG-55 blower REDMAX Hedge trimmers RYAN tow aerator |
#16 (permalink) |
Gold Member
thanks. they are 7,000 lb axles. (2 x 3500)
i see you and i both have similar tastes in small engine equipment. i, too, have the stihl fs55 weed wacker and the bg55 blower! amp
__________________
#17 (permalink) |
Gold Member
rollbar - sounds like a good deal.
also sounds a lot like the trailer i got from Hedererbuilt in Poplar Bluff, Mo a year ago - only mine included the cost of surge brakes on both axels.
__________________
Erik century 2535, loader, box blade, pallet forks, 5' Servus rough cut mower |
#18 (permalink) |
I bought an 18' (16+2 dove) with diamond bed , stow away ramps and a break away box about 3 months ago and paid 1850.00 for it. Sounds like you got a pretty good price!
__________________
New Holland TC35DA with 16LA FEL, Bush Hog sq600 Cutter, Box Blade, 3pt Tiller, Boom Pole, Log Splitter, Hustler ZTR |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
