HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Trailers & Transportation
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 05-29-2008, 09:40 AM   #11 (permalink)
Super Member
EddieWalker's Avatar
Default Re: Nonstick for dump trailer
I'm really impressed with how well the Hammerite sticks to my bed and how smooth it is. I've thought about coating my backhoe bucket with it to see if wet clay will come out better, but so far, it's just a thought I have for the rest of the bucket.
I never thought about a mower deck, but I don't see why it wouldn't work. For the price of a quart, it sure couldn't hurt anything and just might be the ideal solution. Let us know if you give it a try and how it works out for you.
Eddie
__________________
My Goals for 2008
1. Fishing and Hunting with my kids.
2. Build my storage Shed.
3. Put my outside access bathroom together.
4. Fence in a quarter acre for Turkeys.
5. Build my gazebo for my front pasture.
6. Finish back pasture and plant it in Bermuda.
7. Start my food plots.
8. Build a comfortable deer stand for two.
9. Build a wood burning fireplace in my home.
10. New flooring in my home.
11. Build a pasture sprayer.
12. Get my old jeep running.
EddieWalker is offline   Reply With Quote
Old 05-29-2008, 09:56 AM   #12 (permalink)
Gold Member
I have hammerite on my deck. Well its actually called "smoothrite" but made by the same manufacturer. Only difference is it doesn't have the hammered look once it dries. It has a tough almost enamel finish which doesnt chip when it gets hit by stones. It has been on there 2 years now and in my opinion it has held up very well. I still get an accumulation depending on the moisture content of the lawn clippings, but it falls off easy once the accumulation dries out.
Blagadan is offline   Reply With Quote
Old 06-16-2008, 11:55 PM   #13 (permalink)
Member
DUSTMAKER's Avatar
Eddie how long do I need to let the Hammerite cure? I put it on about 27 hours ago and it is smooth and glossy but if I rub my hand over the dust that has settled on the bed it scratches the surface and dulls it up. So far not very impressed. I need to haul a load of sand tomorrow I hope it has curred enough by then.
Paul
DUSTMAKER is offline   Reply With Quote
Old 06-17-2008, 12:10 AM   #14 (permalink)
Super Member
I don't remember exactly how many hours you have to let it cure, but I'm sure you have waited long enough. Mine isn't shiny anymore either, but then I've run hundreds of yards of red clay over my bed, so I can't say to how easy it loses it's shine.
Let us know how it works out for you. I'm very pleased with it and have recomended it to several people.
Eddie
__________________
My Goals for 2008
Old 06-22-2008, 10:30 AM   #15 (permalink)
Quote:
Originally Posted by DUSTMAKER
Eddie how long do I need to let the Hammerite cure? ..snip.. I need to haul a load of sand tomorrow I hope it has curred enough by then.
Paul
Paul... how did this work out for you? I am hoping to find something that will help keep the grass from sticking on my Husky deck. The design is not the best, and after 7 years most of the paint is gone compounding the problem.
__________________
Jim
- Husky W4814- 48" walk behind lawn mower. For my 1.7 acres of lawn.
- '06 Kioti CK30 HST - KL130 loader w/reinforcing bracket, SS QA, LK3054 QA bucket, engine coolant heater, dual rear remotes, KB2375 Backhoe w/thumb, 7ft 6 way rear blade, chains front/rear, loaded rear tires, Kioti Canopy. For eveything else.
IXLR8 is offline   Reply With Quote
Old 06-22-2008, 11:09 AM   #16 (permalink)
Super Member
I moved 160 yards of fairly dry clay yesterday without any sticking. Even with the dirt being fairly dry, I used to have some build up in the corners, but it slides out so quickly with the Hammerite finish that it pulls everything out.
Eddie
__________________
My Goals for 2008
Old 06-22-2008, 11:46 AM   #17 (permalink)
Quote:
Eddie
Great link. Thanks Eddie! Couple questions:
1] Is the hammered finish a rough/mottled texture, or smooth with a rough look?
2] Did you use hammered or smooth for your anti stick results?
Thx, larry
SPYDERLK is online now   Reply With Quote
Old 06-22-2008, 12:01 PM   #18 (permalink)
Super Member
I bought the glossy, smooth finish. I saw that they sell a hammerd finish, but I don't know anything about it. Mine is like black glass, or plastic type of finish.
I'm so pleased with it that if I had to, I'd do it again several times a year. It's holding up so well, that I have no idea when I'll have to do it again, but from the time and aggrivation that I've saved by not having to shovel out the packed in dirt that wouldn't come out, I'm going to keep applying it as needed.
Eddie
__________________
My Goals for 2008
Old 06-22-2008, 01:34 PM   #19 (permalink)
Member
DUSTMAKER's Avatar
Jim so far I have not dumped anything that would have stuck before, pee gravel and sand. The test will be bark and top soil. I will post again when I have had a chance for a real test. I do know that only the areas untouched by the loads are still shinny, the rest is dull and scratched already.
Paul
Old 06-22-2008, 01:50 PM   #20 (permalink)
Eddie I have a 6 by 12 Bri mar dump trailer What prep work was necessary and how far did a gallon go for you ? Did you just do the floor or did you do the sides also ? Thanks V
vettemanwight is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
