#11 (permalink) |
How are the ramps going to come UP
I've never seen a trailer with anything to stop the ramps from coming UP, but of course there needs to be a mechanism to keep the ramps from sliding OUT. In the pictured trailer that is the horizontal rod with the lip of the ramps hooked over it.
__________________
Pround member of the Peanut Gallery |
#12 (permalink) | |
Quote:
__________________
YM 1700 B 4ft howse rotary cutter 4ft bush hog finish mower 4.5ft yanmar tiller 5ft disc 400# fertilizer spreader 4ft box blade |
#13 (permalink) |
Last year I purchased a trailer with the same ramp set up. Skyco is right about the fix, I did just that and it seems to be plenty strong. My tractor is a 30hp with loaded tires.
SPERRY |
#14 (permalink) |
Member
Skyco; What do you mean about the ramps coming up? These ramps are removeable and are placed on the bar each use. My thought after the cut would to put a safety chain/wire between the slot and under the stake pocket.
#15 (permalink) |
I should have quoted skipmarcy where he said-
"Also, those ramps should have some sort of safety to keep the ramp from coming up off the bar while loading - could be very dangerous. " I don't see how ramps could come UP.. I've seen a safety wire/strap/chain/whatever to keep a ramp end from scooting OFF a trailer but never saw the need to keep one from going UP. How is it ever going to go UP? The weight of whatever is being loaded holds it DOWN. Am I missing something here?
__________________
#17 (permalink) |
If you have double jackstands I would leave tractor on it with no worrys. if its a flimsy fold up single I would always have a backup plan, How would you pick the tounge up incase of failure, how would you get truck hooked if single wheel sunk a foot into ground after you left it? before unhooking any loaded trailer besure it has positve toung weight, years ago I unhooked a closed in trailer that I thought was empty. It was loaded with bags of rice all by the rear door, LOTS of negative tounge weight. when I unclipped the latch it slammed the tail on the ground, the tounge just missed the tailgate of a new truck, and it took 5 guys standing on A frame to put it back on the truck.
#18 (permalink) |
Elite Member
My removable ramps, on a PJ trailer, slide on a rail very similar to the pictured BigTex. Rather than stake pockets, PJ used little chunks of steel to hold the "rod" in place and away from the trailer to allow the ramp lip to catch. Cut a little noth in the ramp in just the right place. It will help you locate the ramp each time as well since you will not always have the tractor right there to measure it with.
I use no safety blah blah to hold the ramps down, they stay put just fine while loading. I also regularly unhook the loaded trailer from my truck. Right now my trailer is loaded with a tractor and mower for a quick evening mow job after work. The PJ trailer has a very stout tongue jack with a foot under it. I've left the loaded trailer for months on end. Do NOT consider loading, unloading, moving, or other jacking around of the tractor while on a trailer detached from the truck.
__________________
Kioti CK30HST, FEL w/toothbar, 60" RC, 60" BB, PJ 10k trailer. Weekend warrior hauling 50 miles each way. |
#19 (permalink) |
Elite Member
I have a Big Tex 70PI, it also has the stake pockets. Both of these trailers are utility type trailers and not dedicated equipment type trailers.
Just cut a notch out on the stake pocket in order to get the ramp in place. You don't need a safety cable, I have loaded two different size tractors and one ZTR with no problems with the ramps coming up for any reason.
__________________
Kubota L2800HST, Mitsubishi 372, bh75, 45" Agric tiller, 5' home made disk, 42" Bush hog, PHD, 66" Cammond BB. |
#20 (permalink) | |
Gold Member
Quote:
If you can, this will gain you additional wheel base width on both the front and back. Your trailer has a 2000 lb. tongue jack - that should be enough to support the trailer with tractor. But, as another poster pointed out, if you don't have the load balanced correctly or have supports at the rear of the trailer - you risk the load tipping rear end of the trailer onto the ground. My trailer has drop-down rear supports built into the trailer, and I will not leave the loaded trailer unattached from the truck even with the rear supports down...but, then I'm a belt AND suspenders kind of guy with safety issues. |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
