HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Trailers & Transportation
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 07-15-2008, 05:35 PM   #21 (permalink)
Skyco's Avatar
Default Re: New trailer HELP!****Bummer!
I put one of these on each back outside corner of my trailer-Harbor Freight Tools - Quality Tools at the Lowest Prices
That way I can load and unload without attaching to the truck, very handy. They swivel up or can be removed in a flash by yanking the pin.
Skyco is online now   Reply With Quote
Old 07-15-2008, 10:46 PM   #22 (permalink)
Gold Member
Quote:
Originally Posted by Skyco
I should have quoted skipmarcy where he said-
"Also, those ramps should have some sort of safety to keep the ramp from coming up off the bar while loading - could be very dangerous. "
I don't see how ramps could come UP.. I've seen a safety wire/strap/chain/whatever to keep a ramp end from scooting OFF a trailer but never saw the need to keep one from going UP. How is it ever going to go UP? The weight of whatever is being loaded holds it DOWN. Am I missing something here?
When you start to back your equipment off the trailer and the rear of the trailer starts dropping down the ramp could very easily come off. Or when loading out in a field on uneven or soft ground and your front wheel pops it off the bar when it first hits the ramp and it sinks or tips. My Anderson dump trailer's ramps are hooks like that over a bar and they came with a removeable opposing hook for a safety. A simple pin is welded to the lower hook and is held in place with a hairpin.
__________________
Mahindra 4110, FEL w/5' & 6' QA buckets & forks, 6' Atlas boxblade, 6' Howse rotary, Leinbach PHD w/9" & 12", 1 bottom plow, MF 2/3 bottom plow, 20"x6' bog disc,TSC subsoiler, TSC middlebuster, 6 ton Anderson 12' dump trailer, 20' Hurst 14k flat trailer.
skipmarcy is offline   Reply With Quote
Old 07-16-2008, 09:39 PM   #23 (permalink)
Member
Propjob's Avatar
Hi All!
I have been following all of the posts and did infact cut a slit in the ramp to go over the stake pocket. That appears to will work ok when I get a chance to try it. I do like the idea of some safety latch and am pondering my options. I'd like to place this in the middle. to balance any uplift as there is a slot already there for the ramp locks. The 2305 has a fixed rear wheel. I believe it could be set wider, however the ramps , now put both tires ( by measure up the middle. Once I get it up, and more importantly off the trailer, I'll feel i've accomplished something JIM
Propjob is offline   Reply With Quote
Old 07-17-2008, 12:35 AM   #24 (permalink)
DrRick's Avatar
I have been using a 60CH big tex trailer for almost 20 years and have these type of ramps. I load tractors , cars , trucks , miles , etc. and I have to say I have NEVER had any trouble with the ramps coming off the rear bar. I suppose It could happen, But I just have not experienced it.I also have a number of heavy equipment trailers, like belshe, and bruton, that have exactly the same type of attachment. These are for d-6 caterpillers. I haven't seen any way for the ramp to come UP when it has 35,000 lbs pressing down on it, which in turn presses down on the trailer rear ledge. I cut a notch in mine in order to load the riding mower from time to time. I think many on this thread don't realize just how low to the ground the rear of this trailer is. Upon loading I often only have 6 to 8 inches in height at the front of the ramp to the ground. If it could fall it really might not be that big of a deal . Again- I may have been fortunate but I have never had any trouble with big tex ramps.
rick
DrRick is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
