Page 2 of 8 FirstFirst 12345 ... LastLast
Results 11 to 20 of 79
  1. #11
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,849
    First organized permanent settlement in the northwest territory
    2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
    Default Re: Hauling tractor with a car trailer?
    Quote Originally Posted by Lefty_Kubota View Post
    Quote Originally Posted by George2615 View Post
    A car hauler trailer will be fine for hauling your tractor. If it is a flat deck car hauler rather than open between the tire track rails that's even better since most car haulers have wider spacing between the fenders. If it is open between the track rails you can fill the space with 3/4" plywood, aluminum, or steel decking which will make it a more useful trailer and I think easier to sell later..
    i use my race car trailer to haul my tractor.
    OK so you can use a car hauling trailer to haul a tractor on.
    But can you use a tractor hauling trailer to haul a car on?
    Tractors 2003 Kubota BX1500 / 2004 Kubota Bx23 / 2005 Kubota BX1500.
    Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
    60'' MMM/Clamp on Forks/48'' MMM
    South of Canton Ohio L .B
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #12
    Silver Member Lefty_Kubota's Avatar
    Join Date
    Dec 2008
    Posts
    148
    Odem Texas
    Kubota B9200
    Quote Originally Posted by LBrown59 View Post
    yes, but its usually impossible to open the doors..
    Phil Underwood
    Kubota B9200 4X4,FEL,HST
  4. #13
    Elite Member
    Join Date
    Apr 2004
    Posts
    4,848
    Bay Area-Ca and Olympia WA
    Cat D3, Deere 110 TLB, Kubota BX23, Craftsman Mower
    My open trailer has an open center...
    Open center trailers, at least mine, gives a little more payload because the trailer weighs less.
    I added another rail to fit my BX23 and narrow track antique cars.
  5. #14
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    12,529
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    The problem with doing this is it will add to the weight and take away from the weight carrying capacity. These trailers were engineered to be open and have extra supports in them. A flat deck trailer on the other hand was engineered so that the deck itself give some of the necessary structural strength. What you will end up with if you try to make a open center trailer into a flat deck trailer is one that has a lower than normal capacity and will be just heavy all the time.
    Chris
  6. #15
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,849
    Why can't you open them?
  7. #16
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,849
    Quote Originally Posted by Diamondpilot View Post
    *The problem with doing this is it will add to the weight and take away from the weight carrying capacity. These trailers were engineered to be open and have extra supports in them. A flat deck trailer on the other hand was engineered so that the deck itself give some of the necessary structural strength. What you will end up with if you try to make a open center trailer into a flat deck trailer is one that has a lower than normal capacity and will be just heavy all the time.
    Chris
    *This makes sense.
    So then what do I need for a trailer that will haul both?
  8. #17
    Elite Member wushaw's Avatar
    Join Date
    Mar 2005
    Posts
    3,075
    Bristol Texas
    Kubota L2800, 15 hp 372 Mitsubishi
    *This makes sense.
    Lefty has exactly what you are looking for, it will haul a tractor, truck, car, atv, utv, golf cart, motorcycle, trycycle, bicycle, furniture, appliances, firewood, plywood, sheetrock, 2x4s, 4x4s, 2x2s, 1x2s, 2x8s, 2x6s, manure, gravel, dirt, sand, sawdust, compost.....and whatever else you can put on it.
    But there is one thing it will not haul....@**....no sides to keep him from jumping off.
    Kubota L2800HST, Mitsubishi 372, bh75, 45" Agric tiller, 5' home made disk, 42" Bush hog, PHD, 66" Cammond BB.
  9. #18
    Join Date
    Jan 2007
    Posts
    12,529
    Daleville, IN
    Yep, that is basically what I have but with a wood deck. Its a 7,000# 18' by 76" wide trailer with a rail. I have hauled a Suburban and 20 other cars. The longest haul was a Lincoln Aviator 250 miles from Detroit Auction. Its fitted with a winch and a strap box on the tongue so everything is always right there. It also has a spare tire on the opposite side.
    It has hauled everything listed above and then some.
    Chris
    Attached Images Attached Images
  10. #19
    Bronze Member L-ENTERPRISES's Avatar
    Join Date
    Oct 2007
    Posts
    55
    CANADA
    JD 1250 , LA145
    I haul my 1250 on this ....a solid deck 18' beavertail car trailer , its 9999gvw .Payload of 7200 lbs . I ordered it with galvanized rims too .
    Attached Thumbnails Attached Thumbnails Hauling tractor with a car trailer?-picture-007.jpg
    09 J DEERE 5101E, 101 HP, MFWD,CAB W/HEAT & A/C
    05 J DEERE 5425 65HP 4WD CAB W/HEAT & A/C
    08 J DEERE LA145 , 48" FM , 22HP
  11. #20
    Member
    Join Date
    Feb 2007
    Posts
    47
    Northeast PA.
    NH TC33D
    Thanks for all your input !! I think I will be alright going with the trailer I'm looking at. Weight wise the trailer will handle it. Being an open center I have plans to fill the center with removable decking making the trailer able to be used either way, open or full deck. I checked the brimar website and the full deck trailer weighs about 360 lbs more than the open. The price seems good @ 1300.00 for a 2004 trailer.
    NH 7308 FEL / NH 757C Backhoe / 5' KK Landscape Rake / 5' Inland Snowblower / 5' M-B Ind. Rotary Broom / 6.5 foot Meyer Snow Plow / Cub Cadet Spreader, BearCat 70554 Chipper/Shreader
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
