JB4310
Super Member
OK. Now that I finally got an Equipment trailer I need to learn how to secure loads properly. For now it's a JD4310 and a ford 1700.
I have moved the JD in my dump trailer but that was a hassle working with only 4 D-rings and the high sides in the way.
As far as connecting to the trailer, I have the stake pockets and rub rail, I think most will say drop chain thru pocket, come up underneath and hook on upper edge of pocket.
That's pretty simple and if it's the acceptable way of doing it, I can live with that.
What I would like is pictures of how you connect to machine.
I have plenty of HD 3/8 chain, 4 chain binders, 2 ratcheting web straps. just bought a couple hundred dollars worth of acs at AWdirect yesterday so I don't mind if it's overkill.
I've got a 20' trailer so there's no problem for fit, the guy I bought it from put a couple of tool boxes on the front of the deck and I would like to keep them there as they are handy for storing chains etc. the only problem is I can't pull the tractor up tight to the front, but since the trailer is so long I probably want to dock it back a little to balance the load. Should I bolt a pc of 4x4 down on the deck to pull the tractor up tight to or is that not necessary and the load binders will hold it in place with out stops?
Pictures help me get the idea quicker
if any one has any.
I'm going out now to experiment.
Thanks
JB.
Thanks
JB.
